Hi, I’m Indy (it’s been my nickname since long before Harrison Ford appeared in American Graffiti).  I’m new to watch repairing, just watching a lot of YT stuff at present to learn as much as I can.  I’ve gotten a lot of the tools to start with, and my first project will be the pocket watch I inherited from my Grandfather, just waiting for the lubricants to arrive so I can get started.  Anyway…pics of the watch are attached.
Hello and welcome. That's a nice watch, with a fine regulation mechanism I've not seen before.
You might want to practise on something less important to you.  Most of us caused some level of irreversible damage to the first watches we worked on.
 As said, start with inexpensive watches say seiko 5's  for parts /in need of repair perhaps even some scraps. Stay with one calib  Seiko 7009 for instance, you would then have your own inventory  of spare  parts and save $ £ €. Select pieces so you can eventually  makes at least one good running watches out of them all.
Welcome to the forum Pal.
Edited by Nucejoe
Correct
Can't stress this enough! That is an exquisite watch, and best set aside for a year while you gather some experience on movements you can afford to damage. Welcome - this is a very helpful forum.
Hello and welcome to the forum.  You have had some very good advice regarding  putting this one aside and honing your skills on cheap jobs that will stand a bit of messing about with. Best to destroy a $10 watch than a family piece.
what does it say on the dial, I  can't read fancy writing.
Hampden Watch Company - Hampden was one of the big American watch companies (but still a tiny maker when compared against the giants Waltham, Elgin)
100% to all of the above!
@Indy, PLEASE practice on a few other watches before.
Hi again.  A little history on the watch I want to ultimately work on.  It is a Hampden Watch Company, Model 4, William McKinley, 17 jewel.  It belonged to my paternal Grandfather, a great man to me as I was growing up.  I looked up the serial number, and learned the watch was made in 1915, which means my Grandfather would have gotten it when he was 17 or 18.  I don’t know if he purchased it himself or received it as a gift.  At this time, the watch doesn’t work, I think it’s a broken mainspring.  When I opened it recently, I got the balance running for a short time.  When it was running, it appeared to keep time well, but since it was only running for about 1 1/2 minutes, I didn’t have time to check it accurately.  I don’t yet know what size mainspring to get, I think there are four sizes for Hampdens of the period.  So I’ll have to measure it once I open it and begin the repair.
In the meantime, I’ve been watching a bunch of videos, mostly Wristwatch Repair, and Watch Repairs Tutorials on YT.  Fortunately, mechanical things come extremely easy to me (I took my bicycle apart, including the rear hub, and put it back together when I was 10.  I’ve had automobile engines torn apart and put together again, without ever going to an auto mechanics school.  My brain may work a little differently, as I can easily learn by watching a video, or watching somebody else doing a job before I get “hands on”.  Still, I’ve gotten a Seagull ST36 to do some practicing on before I tackle the Hampden.  The ST36 is the closest I’ve been able to find to the Hampden, the watch works appear the be similar, also the off center second hand appears to be similar.  I’ve also gotten a bunch of tools in preparation.  Hopefully I’ve made a good choice with them.  (I was thinking of getting a kit from Sutcliff Hansen, but decided to search for my own through Amazon.). Most of what I got appears to be what Sutcliff Hansen offers, and I got a huge discount by opening a Prime account at the same time.
Anyway, if you’d like, I’ll keep you posted, and post a video of my Grandfathers watch running once I fix it.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
