I believe that the cannon pinion for this movement is not friction fit as it seats on a tube that the center wheel traverses. There is a retaining plate that secures it to the main plate. Can anyone verify this for me please?
4 hours ago, nevenbekriev said:
The part that is friction fit and plays the role of cannon pinion in this movement is pointed with red arrow here:
How do I know how much friction is enough?
I'm not sure if this is the proper way to test it but whenever I suspect a cannon pinion is loose, I'll use a pegwood to stop the minute hand and see if it can stop the balance wheel. If it stops, the friction is enough. If the wheel slows down but continues to turn, the cannon pinion is slipping.
