Hello everyone! I recently bought two Jacot tools both in great condition, I want to get rid of one of them because I don’t think I will need both of them, but I can’t make up my mind on which one would be best. I need some advice or opinions on these two beauties that can help me make the right decision. Thanks everyone!
Who are the tools' makers? If either is a Steiner, keep that one because it is possible to get replacement parts from Horia.
Either of them looks like a fine tool though, and both have the hard-to-get big center wheel runners. Nice.
keep the bottom one, it looks like it has the internal drive feature and an extra spindle
more modern so might have had less use ,but rob the burnisher from the top one.
no ! in fact keep both, watchmakers need at least two of everything..at least...so start looking for two more...at least.
  • Haha 2
The one in the unlined box is Steiner, and would be my first choice for sure. Replacement parts are available, and they are adjustable for alignment, unlike any other Jacot tools.
Do have a look at the Steiner to be sure all the runners are there. There are spots for 3 double ended ones, but sometimes there's a 4th which is in the tool. The numbers should go start (smallest size) at 4 or 7, and go up in consistent steps from runner to runner. It would be a shame if there was a runner missing, and if there is, perhaps the other tool is the better choice.
Thank you all for the replies! I am having a hard time deciding which one to keep. I love both of them, but I don’t know how much I would use them if I kept both. They both seem complete to me. Well, the Steiner has a broken lantern, but what I like about that one is that already comes with a built in string to turn the pulley on the headstock. And it has two spindles for different size pivots. On the other one, all the lanterns are good, and it also seems to be complete.
By the way, where or who sells parts for the Steiner Jacot tool? Maybe I can buy the lantern that is broken and keep the Steiner.
If one or few holes in the disc are broken, is of less importance. In almost all cases you can use just one hole. They don‘t have to fit the pivot, just the edge behind the pivot must run inside the funnel.
Frank
Frank
Thank you Frank. I didn’t know that. I thought the hole had to match the size of the pivot. But that’s great news since the broken lantern still has several useful holes.
44 minutes ago, mbwatch said:
https://www.horia.ch/en/Products/Pivotinglathe/Accessories/Lantern-N-1-N-4.html
There was an older thread revived last month about this
Thank you for the link mbwatch! I will see if I can find the lantern that I need!
I checked the runners, but they all have a number 5. However, in the ends, they all have different numbers going from 4 all the way to 120.
Good that they all have the same number, that's a matched set.
Now check that the numbers on the ends are continuous. That's to say there's no gap in the sizes. I have two "big" Steiner sets, one with 4 runners and one with 3. Both cover the same size range, but one goes in 0.005 increments on the small sizes. That one goes:
4-10 1/2  in 0.005mm steps
10- 151/2 in 0.005mm steps
16- 36
then the double ended (center wheel) runner has:
38-65  /  68-100
The three runner set goes:
4- 15
16- 36
38- 65  /  68- 100
I'm wondering if your box was for either set, and has an empty space because it was delivered with a 3 runner set, or if you have a 4 runner set missing a runner.
Edit for clarity- I'm talking about the long runners. The short runner is for tapered extended (4th wheel) pivots.
Edited by nickelsilver
Steiner did make "old style" Jacot tools before moving to their unique design. The trademark is still a rooster, but flanked by the initials C and S. They are fine tools and unlike most competitors already featured replaceable beds and lanterns. I do strongly prefer the more modern ones, as they provide means to fine tune the alignment of the pulley side (headstock) to the runner side.
An old Steiner
The old Logo
The adjustment mechanism on the modern Steiner
16- 36
38-65  /  68-100
4- 15
16- 36
38- 65  /  68- 100
Excellent information, my friend! I am very new when it comes to Jacot tools and I would have never known this u less you had told me. I will double check the runners numbering to see if there anything missing.
2 hours ago, VWatchie said:
Keep the Steiner, and if you're new to Jacot tool work you might find this video helpful.
Thank you for sharing the video Watchie. I will for sure keep the Steiner. I just have to make sure everything is correct. Which I think it is for what Nickel silver was teaching me on his reply. I think there must just be a runner that he mentioned that I may not have which is the one that goes from 4 to 10 1/2. But the other ones seem to match the one I have.
16- 36
38-65  /  68-100
4- 15
16- 36
38- 65  /  68- 100
Hey, Nickelsilver! I checked both Jacot tools.
the Steiner goes from:
4-15
16-36
35-75 in increments of 5
75-120 in increments of 5
then the other which the brand says Bechtold goes from:
5-14
16-34
40-65
70-100
Does all that sound ok to you? Or you think there is something off?
Sounds good- would definitely keep the Steiner then. You have a very nice tool there.
That one is a cause for envy! The largest beds in my Steiner set are in a runner ranging from 38 to 76, and more often than one might think, it is too small for some centre wheels. Getting a larger runner from Horia is very expensive.
For even more info about this, check out this post, also by @nickelsilver!'
Edited by VWatchie
That is great to know! I am glad the tool is complete! Thank you all for helping because I had no clue what I had bought. I knew the tool looked nice, but I did know if everything was like it is supposed to, but now I have peace of mind keeping that one.
    • That’s a nice idea, But i’m committed to providing this site as a gift to the watch repair community as my thank you for my incredible life i’ve had in this business. Ive done well and unless my financial circumstances change then i’m more than happy to foot the bill. If circumstances do change then be assured that I will make an appeal. For now, I’m comfortable with the way things are and I am extremely delighted to remove Google Ads from this site and to stop Patreon, it feels like a major step forward 🙂 Sorry, I missed your reply, I got blinded by another poster in this thread. Yes - I can confirm that I have always seen WRT as a not-for-profit website, and therefore - not a business as such. I’m lucky and have done well in my life due to a decision made in my teens to start a watch repairing apprenticeship which has sustained myself and my family for many years now. Consider this my small way of paying it forward. Ive been committed to keeping the site alive on a technical and financial level for over 10 years now and I have zero plans to change that. Thank you for your kind words by the way. And as for your wish - nobody can control what happens in life, if something happens to me I have things in place with my family but I’m just not comfortable talking about my personal business - I wish a certain person would respect that, but i’ve calmed down now - i’m only human 😄
    • Yes, exactly. I've seen a few different versions, but mine has the blue water symbol, not white.    I think it's Acrylic. The case is plastic so I would the is the lens would be too.
    • Hi there Josh, welcome to the forum.
    • From the same listing, the back side: I would guess that the back pops off rather than the front. You can see a little groove there where the caseback sits over the winding stem, rather than a case tube. Look for an indent or notch around the back. It might be possible to pry this off from almost anywhere on the back if it sits right against the rubber strap. The movement looks like it is from the Ronda RL family (015 or 115 or something? I forget which numbers have a calendar and which don't)
    • I'd expect a similar notch somewhere around the rear to pop that off.
