Pliers identification and other unknown tool
From a random lot of mostly clock maker tools:
What is the purpose of these pliers, with a 90° inward bend and a slot opposite? They are pretty large.
And how about this tool: it has a spring loaded central part that turns and locks into place. When unlocked, the central flat part is about 45° rotated from the two points, and even with them. When locked the inner flat is aligned with the points but slightly recessed in. Labeled Ullman Devices, PD-10
PXL_20250223_005150275.thumb.jpg.1d2e6b91c553c9733890d87d9051a5c7.jpgPXL_20250223_005134547.thumb.jpg.173d05107a26f50b4008a12763e98844.jpg
The second one looks like a screw starter. You wind it till the flat is inline with the prongs, put in the screw slot and release. The spring tension displacing the center section holds the screw making it easier to get it started in the thread without dropping it.
Tom
That actually sounds like a lot of work.
Oh wait, this might be for unscrewing tough screws. When locked in place, it fits over the screw head and if you push against the screw it unlocks and snaps 45° counter clockwise. Still hard to see how that could offer more torque than just unscrewing it manually.
EDIT: @tomh207 is right, and you can still buy this tool.
Edited by mbwatch
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
