First, hello. New person on here. Anyway, I saw this question somewhere: when I put watch in the water and release the air pressure, bubbles come out from under the bezel. Then stop. Is this a leak or trapped air? Rolex Submariner used.          My experienced answer, and info for anyone. When the air and pressure is released any air bubbles outside the watch and under the water expand and grow from really tiny to large and so then escape from where they are. Under the bezel. They usually just come out from under the bezel and hang on the watch. This is not a leak. If a leak there is a stream of bubbles or the bubbles keep expanding and release to the surface and another bubble forms, etc...        When there is no leak the compressed air compresses on the OUTSIDE of the watch and when put in the water and air pressure released from tank there is nothing to expand from inside the watch because there was no extra air pressured into the watch thru a leak in the case, which would expand inside the watch when pressure released and cause air to go out the watch hole leak, or even blow out your crystal. Release the air semi slowly from the tester, less chance of crystal blowing out. If released real fast it causes the watch to have the bends if there is a leak hole and  blows the crystal out. Like a person to fast to the surface. Being Jettisoned into outer space comes to mind. All air in you escapes from you really fast into outerspace and blows your crystal out! Ha!   So if bubbles come out from under bezel, but stop growing immediatly and just hang on watch, no leak. Grow bigger and release and repeat or string of bubbles, that's a leak. And water does not get in a watch that does the leak type bubbling because it's pressurized air escaping so it's not trading places with the water like a watch in a bathtub does that's not pressurized. If it is bubbling in a leak like manner like I described, do remove immediately and fix or take to an AD. And this tester works great for me. It goes to 6 ATM/200 feet. Im not a diver so i usually test at 3ATM/100 feet. Less sress on my watches and their seals and plenty for swimming. Happy Submarinering! Hulk style!
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
