I haven’t broke the barrel arbor screw  yet but it’s really tight. Put some 3 and 1 oil on it and letting it sit for awhile. Hoping it will seep in and loosen it up. I’ve run into a few left handed barrel arbor screws and wondered if any one knows if the AS 554 has a left or right handed screw. Unfortunately I usually find out it’s left handed when the screw head twists off.  Hoping to avoid it this time. IMG_8730.thumb.jpeg.def4894806541647a253d141676ae9b1.jpegIMG_8731.thumb.jpeg.bc4628c4bee552b52bfe968c6be8d0be.jpegIMG_8733.thumb.jpeg.4c79e492df09b44fa025411e258f4d7f.jpeg
Oops , sorry should have introduced myself first. From British Columbia,  started around a year ago repairing watches. Really jumped in the deep end with this one , also think I’m addicted to eBay. Great place to find parts tho.
  I see balance is already removed, so next time, giving the watch a 10 hrs soak in Coca Cola, loosens every screw. Works  far better than any oil.
 Oil on ratchet screw will at best loosens it, but wont get to barrel arbour, Coca Cola soaks, however, soaks  the thread of barrel arbour as well , when you drop the whole movement( less balance& fork) in Coca Cola thus , less force is required to loosen the screw than takes to break it.
Loosening without breaking, thats an advantage .
Welcome to the WRT forum.
Edited by Nucejoe
Furthure expalanation
Almost all the left hand threaded barrel arbors I've come across have been on AS movements.
The problem is when it hasn't been dismantled for years, and you cannot tell if it's stuck or reverse threaded.
I'm always careful when dismantling an AS - I try to turn it the 'normal way' to unscrew just a TINY amount. If it's a clockwise thread it will loosen, but if it's reverse threaded it will break the stiction with no damage done.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
