2 minutes ago, Nickpan said:
yes and yes
My first thought is although the listing shows this
they're not genuine movements and that's where the fault is.
1 minute ago, ColinC said:
Perhaps a stupid question.... but when you do the case up tightly are you pushing the seconds hand into the crystal?
I'd thought that but would have expected it to stop pretty much straight away.
yes, fair enough, it was Aliexpress, at best I may have been unlucky with the case
If the rotors aren't smooth and have too much play then I'd put it down to them.
hmm, that would suggest it had run out of power and wasn't re-winding itself (both movements), but I manually pre-powered it by turning the screw on the mainspring
Edited by Nickpan
Sorry I didn't mean it was down to the rotors and lack of power but down to the movements themselves in general.
I realise I have a brass dial, which tend to be thicker, so that will be my next thing to fiddle with.
Watch has been running fine for 24 hours now, but with the back cover v-e-r-y  loose!  Not ideal, but it's nice to see it on my wrist ticking away.  Have a bad feeling it will stop again, them I'll measure the dial thickness.
15 hours ago, AndyGSi said:
Dial should be 0.4mm thick.
yes, it seems brass ones can be up to 0.8mm, which could be the difference between a loose caseback, and a tighty!
A 0.8mm Dial would only give 0.2mm clearance for the Hour Hand instead of the 0.6mm specified (unless you've got the L (HH) version).
and what is the height difference between a loose case and a tight one  - one doesn't have to look very far to find a watchmaker saying 'every thou makes a difference'  🙂
Edited by Nickpan
  • 4 weeks later...
I asked the same question on 'Seiko Mod' Facebook page, general opinion was 'your watch stops because the hands touch the glass'.
So, I trimmed the seconds hand by about 5mm, aligned it to be a lot close to the second hand, and gavethe central pinion bit an extra press, squash the seconds hand down.
Works a treat
winner  🙂
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
