Swiss Waltham FHF 90-5 restoration; removing movement
Hi guys. I just received this movement to practice on. Unfortunately I cannot figure out how to remove the movement from the case and I cannot find any information online. I removed the crown and stem and that did not help although it allowed me to rotate the movement but that also did not help. + it seems like that Silver Band just on the inside of the case needs to be removed before the dial and movement can be removed but I'm not sure. It does not appear that it comes out of the front face of the case as there is no bezel that can be removed. I'm also not seeing any case screws although it looks looks like there could be a couple of screws missing where a case clamp might have been if you look at the 3:00 position on picture #2. But I don't think that is relevant to removal because they are already missing.
My other question is how to remove the retaining clip on the automatic rotor. I'm not sure if I should put a screwdriver in that Half Moon opening and then pull away from the center post or if there's some other trick that somebody knows about. Anyways thanks for any input you can provide. Arron
edit: I just noticed that there is a screw (encircled in blue) that can be lined up with the stem opening in the case.  I can't tell if that would have any effect on removal of the movement, but maybe somone knows.
I just found a video that @jdrichard did with a similar, but not the same model, watch.  He lifted the glass and took it out from the front.  i'll try that and report back.  I've never lifted a crystal before so hopefully i don't break it.
Edited by arron
Here's an update: I was able to remove the crystal but unfortunately the dial was too big to come out that way.  After removing the very brittle gasket around the perimeter I was able to rock the movement and dial a little bit to break free a lot of the gunk that had accumulated over the years causing a tight seal. So Long story short the movement does come out from the backside not the crystal side.
Still wondering how to remove that C clip retainer.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
