Hey there.
Working on restoring one of my first watches, an AS 1187. However, both the incablock jewel settings and caps are missing. I've found a few on ebay, but with US/CAD conversion and ebay's shipping program gouging and now potentially tariffs, the two tiny parts have gotten to be very very expensive ($50+), which is nearly more than the cost of the movement.
It seems the parts are broadly compatible across a lot of movements, but I can't find any non-ebay suppliers, but I'm fairly new to the game. Any suggestions for vendors that typically sell these jewels? I'd rather avoid having to hunt down a junk donor movement, since it'd just gather dust afterwards.
Thanks for your help and advice
3 hours ago, VanDan said:
vendors
The definition of vendors would be watch material house at least that's what I call them. They used to be scattered all across the planet or basically anywhere where watch repair occurred if you weren't a bigger city he probably had one or more material houses. Some of them like cousins realize that not very many people came to visit so they went online 100% online in the case of cousins. Others are only partially online which is why you have to either email or call to see if they actually have what you need because they may not list everything. Then there's still a whole bunch of material houses that are lurking out there that aren't online barely at all. Plus the added problem of some of them for variety reasons will not sell to basically hobbyists. In other words the only sell to people wholesale or have business licenses etc.
So the first link I are ready knew about as I've seen references from other people that exists down as I just found by searching for watch material houses in Canada I suspect they're probably more.
https://perrinwatchparts.com/en-us
https://swisswatchmaterial.com/
https://reliablewatch.ca/
https://somalcanada.com/
Thanks John and Andy. I'll try to find watch material houses, now that I know the term to look for.
Much appreciated!
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
