I have a Waltham permaforce Incabloc watch I inherited from my grandpa.  Nobody wanted to watch because the crown had been broken off.  I've taken the watch apart, and been able to identify the screw to remove the stem. On the site was mentioned that I can find the model number underneath the balance. I found the numbers 1123 and 1124, and believe these may be the movements model number?
As I try to spin the screw to release the stem, it won't budge and I'm worried that I'm going to damage the movement. Should I lubricate the screw? Should I find a smaller screwdriver? Assuming I'm able to get the stem out, what's the best way to get a new stem and crown for this watch?  Folks thank you so much in advance for your help..
28 minutes ago, AndyGSi said:
Welcome to the forum.
Which screw are you trying to remove and do you have the equipment to remove and replace the hands if necessary.
He's trying to loosen the set screw.
I don't know which size of screwdriver you tried, you need on the correct size.
I should have been clearer, I know he's trying to loosen the set screw but do they know which is the correct screw.
Thank you for the replies.  I have a very small screw driver, but it must not be small enough, and I'd resolve to buy a set of watch tools.  The set screw (didn't know that's what it was called, thank you) I'm trying to take out is the screw closest to the stem, if the stem is facing north, I believe the set screw is just to the left (picture below).  I hadn't anticipated the hands coming off, I'm sure I'm doing this wrong, but I set the dial on an open platform, so the hands weren't getting pinched while I tried to get that set screw out.  Best to take the hands off first so they aren't damaged? Should I not take out the stem and try to find an extender and crown that would fit?
I mentioned removing the hands and dial as a last resort by giving you direct access to the setting lever.
The screwdriver head should be the same width as the screw and sit in the slot so it touches the sides without bottoming out.
You could try a stem extended but this would need to be secured with the movement in place.
Also finding a generic crown wouldn't be a problem.
Edit
Can you post a photo of the movement back in the case as to me the stem looks long enough.
Edited by AndyGSi
So it does look like it would take a crown with a short tube directly but this has raised another question as to what should be their as a pendant tube.
Hi AndyGSi, I had to look up pendant tube, I wasn't familiar with that term.  Only with that question did it occur to me that even with an extender and crown, without the pendant tube, this wouldn't be water resistant at all.  Sigh.  Is my best path forward going to be to buying a similar one on eBay and making a Frankenstein?
I don't think you'll need an extender just the correct type crown.
Can you measure the hole size where the crown fits.
With this type of arrangement you're never going to get any sort of water resistance.
Edit
Think this is what yours should be like.
Edited by AndyGSi
That looks exactly like what I need.  Should I buy the crown as part of the crown kits sold on Amazon, where they sell 100 crowns? Or should I buy one especially made for this?  How do I know how much stem broke off with the last crown?  I think I should probably still take out the stem so I can get the new crown for on snuggly.  Is that what you would do?
The ones from Amazon in packs of 100 are too cheap for this watch, you need something better quality.
You should be able to grip the stem with pliers while you fit the crown so no need to remove it.
Can you post a photo with it in the case back to see how close to the edge the stem is.
Edit
Can you also confirm the size of the hole when both case parts are together.
Where in the world are you?
Edited by AndyGSi
Got it, no Amazon.  I'm in the USA.  The opening is just less than 2mm.  The distance from the stem to the opening is less than 1mm.  The stem is basically at the opening.  I think the pics I just took show that?  Thanks again for all your time AndyGSi.  Really appreciate it.  I'm getting excited to get this on a wrist again.  It's been out of action for a while.
Wasn't 100% sure from your original photos but if anything the stem looks too long but it can't be.
So the next question is what diameter does it need to be.
Looking at this example I'd say maybe 5mm.
Edit
What diameter is the thread along with a more accurate diameter for the hole.
Edited by AndyGSi
1.778mm or .07 inches is stem opening hole.  .8382mm (.033 in) is the stem thickness. I've taken a few better pictures of the end of the stem.  I'm fairly sure the crown snapped off, due to the angle of the end, but I can't know for sure.20250310_222311.thumb.jpg.be2441b0a06debf8747748d6ddfec92c.jpg
Edited by nenyon1
Extra pic
24 minutes ago, RichardHarris123 said:
Something like theses, range from 3mm, to 5.9 mm
Not sure if the .8382mm measured is correct as I'd have expected a 0.9mm stem.
Very possible I've not measured in the right way, plus I'm converting from a caliper that measures in inches...  I'll give it a few more shots and report back.  Thank you all again for the guidance.
When you find the correct screwdriver for this, take note that you should not unscrew it fully. This screw punches through the main plate (main body of the movement) and attaches to a component on the dial-side called the setting lever (hence the screw's full name, the setting lever screw). If you were to unscrew this completely, the setting lever would fall off the end of the screw and you'd have to remove the dial and hands as well as other components of the keyless works to reattach it.
My rule of thumb: 1.5 turns (three half twists) is usually sufficient to allow the stem to come out without much fuss. When reinserting the stem, insert it fully and gently tighten the screw. If you feel resistance, wiggle the stem back and forth and tighten more. You're encouraging the setting lever to find its slot in the stem.
edit: then there's the question of whether the stem should be in the winding or hand setting position when removing it... on some movements it matters, on others it doesn't. I usually pull it to the setting position.
Edited by fellerts
another thought
I opened the calipers to. 9mm, and it's visibly to big, it doesn't touch both sides of the stem and easily slips through.  .8 is too small, is there a .85 possibility for this stem, or is it either .8 or .9?
They only do 0.8mm & 0.9mm stems and wasn't aware of a 0.8mm for the 1123.
Edit
It's while since I've needed to measure a stem but the 0.9 does measure about 0.83/0.84
Edited by AndyGSi
This is important! Only loosen that screw bit by bit until the stem releases. Otherwise you'll have a mess on your hands.
Stem doesn't need to be removed
Of course the exact one I want is out of stock.  For the price, I'll get several in the 9 range and one in the 8.  I'm confident 8 won't fit, but just in case so I don't have to pay for shipping twice.
When it arrives, just stabilize the stem and screw it on?  Any thread lubricant or product I should use?  My only doubt here, these will fit through the hole in the side of the watch?  I don't see that outside diameter measurement listed on the cousins website.
  • Similar Content
    • Did you just swear at me matey?? I’m sorry, I’m not divulging personal information but there’s always personal reasons. There’s not much more than I can do other than plod along as best I can. However, my health is good now and I’m regularly getting plenty of exercise to keep it that way 👍 You know what. The ads don’t even cover a small percentage of what it costs to serve this site. I find most of it personally. If there are complaints then so be it. I do my best.  in fact - I have zero issues turning them off. Would that make the complainers happy?
    • Same question that was asked last time Hakan, and emphasis was placed on it. It was ignored. The thread should still be there, if not I have a copy of his reply.
    • This is probably the single most important point. One of my best friends, 48 years old at the time, suffered a massive stroke about 15 years ago. He barely survived, but his life was never the same after that. If you had asked me back then to guess which of my friends might have a stroke and nearly die, he would have been the very last one I'd have picked. He was perfectly healthy, played tennis three times a week, ran a successful business, was full of life, and had a wonderful wife and well-behaved teenage kids. The harsh truth is, we never know when it’s "game over." @Mark, I truly wish you a long, happy, and successful life. But have you given any thought to some kind of backup plan for WRT in case the worst should happen? Is there anyone who could keep the site going? If you can reassure us in some way, it would mean more than a lot to us!
    • Update: The demagnetization only helped temporarily, maybe it pulled the wheels into a position where they liked each other. I have to adjust the sub second hand as it is a bit angled upwards and catching the minute hand stopping the whole movement but before this happened there were some wild deviations. HWGIKE#58 Alarm clock, cooked in hot cleaning fluid and oiled gently. This is a movement so I count it. 🙂 A while ago it tried to fly away one day, it was on my windows sill, we had strong wind the curtain flew like a flag and doing so encouraged my clock to do the same...  went out and ended up on the roof above the entrance door, its door in pieces but the clock itself suffered no damage otherwise. The original glass was already broken when I received it I still have the bottom part in two pieces. The new "glass" is acrylic. It also had a paper in the back in the case inside but it disintegrated, I still have a little bit of  piece of that too.     HWGIKE#59 Durowe 870 / Times M84 This particular instance is a D870, when I saw its worn out contact pin I thought that it must be a design flaw, and here we go: https://17jewels.info/movements/d/durowe/durowe-870/ An incredible movement again where the balance wheel drives the train and has two magnets one for the balance wheel/coil and one for the pallet. The magnet for the pallet is basically the "draw" one direction. The coil is about 1.8kOhm and one end is in contact with the main plate and the other end is soldered to a contact pin which is insulated by the means of putting it into a jewel and this contact pin is rubbing against a wire getting the energy/impulse as it is passing. Behind the contact pin there is an "impulse jewel" not sure why is it there... the wire seems to hit the impulse jewel first then the contact pin but maybe it is there only for insulation purposes? I was almost certain that the screw holding down the battery - (minus) clamp had no insulation washer.. i only noticed the green stuff around it coming from battery leakage... anyway the + and - had a shortcut which took me a while to realize.. had to fabricate one insulating washer on my own. The jewel settings were dirty but not it is all cleaned and oiled. The contact pin might work for a while but I am sure it has a short life. It is a front loader the whole thing is held together by the case so it is not possible to regulate it without putting it all together and taking the movement out of the case again, very inconvenient. A wonderful movement but not made for eternity only for the consumer market.
