Hi
I have an unbranded watch called Space liner. Its probably from the 60s
cal2452. ETA 30j
there is nothing in the case back
any ideas. I’m told this movement is found in Tudor watches
  A watch may have two or more signatures stamped on it, even  on hidden parts, I guess your watch's winding crown isn't signed?
 The manufacturer proudly pronounce it , ASJUSTED IN 3 POSITIONS and 30 jewels,   Rado  or Fortis probably, or other name brands.  You can find such  30 jewels calibers  in lower quality watches , that say unadjusted.
Heres a link to good ole Dr ranfft data base,
 https://ranfft.org/caliber/4037-ETA-2452
 Some 30 jewel versions had detached manual wind complication,  if reverser wheels  ( doubled wheels) don't turn when you give the watch a hand wind,  it's a detached manual wind.
Welcome to the WRT forum.
Edited by Nucejoe
Correction
14 hours ago, RichardHarris123 said:
Hello and welcome from Leeds, England.
I don't understand your question.
What make could the watch be. It’s unbranded
What make do you think or know it could be?
In the 50s and 60s everybody jumped on the theme of space.  This was either a microbrand that wanted a piece of the action or possibly a sub brand of a bigger company. Either way the movement is unsigned. One day some info might turn up that points towards a bigger brand, but for now it's just a "Space Liner" watch that ETA  made the movement for.
Edited by Neverenoughwatches
 General public shop by brand name &  style, fashion, adverts, wifes choice ,...   etc ,watch folks , however , go by  the quality of the movement and health of the heart.
 Your watch proudly anounces adjusted in three positions, one or two more positions would have been qualified for COSC standards.
 Being this old , I would be concerned if its balance complete is the original, unmolested, not re-staffed by watch destroyers like me and not a replacement with lower grade balance completes.
Rgds
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
