What lubricating products should I be using for a watchmakers lathe?
11 hours ago, GregG said:
So the entire rear bearing spins.  The keyway pin, and everything connected to it, up to the split metal ring, all spins.
That's the inner part of the bearing!
The key pin shows it is intended to engage the key slot on the spindle and turn with it.
[edit - accidental duplication].
Edited by rjenkinsgb
So I've got the entire thing reassembled.  I don't think the PTFE was cutting it for making the slide assembly and tailstock lever run smoothly, so I still coated things in some oil.  But I didn't do a very good job of making the application even and consistent.
There are some spots that look good, and some spots that have small blobs of oil. Exactly how much oil do I need on these parts, and what is a good way to get an even application?  I was thinking one of those foam paint brushes would probably give an even coat and it could easily get into crevices.
Edited by GregG
1 hour ago, GregG said:
I also purchased 5mm belt.  Is this too big for the pulley, and should I go down to 3mm?
I would think the key points are, that it spins the pulley and doesn't slip either there or at the drive, and not so much tension that the bearings are strained. It does actually look too thick !
Edited by Neverenoughwatches
Fits nicely in the v-groove. I don't see why you should use a thinner belt, unless this is to big for the pulley on the motor..
And how do you determine the proper tension?  I am currently using a bench grinder that I removed the grinding wheels from.  I 3D printed a copy of the pulley from the lathe and put it on the grinder.  Alone, the grinder is actually pretty quiet, but things get noisy when trying to run everything together.  The belt wobbles a bit, even though the tension on the belt is pretty high.
I'm thinking it might be due to the belt width.  I don't think the belt is supple enough at that thickness to be able to curve as tightly as needed without fighting back a bit.
I'm far from any expert in lathes Greg, my own trade is different but I do and have used a lot of bench equipment. So with my 2 lathes, I tension the belts until they don't slip and then a touch more. So with a thick belt you would set them to a non slip and that extra touch could be too much on the bearings over time. A thinner belt would have more adjustability providing it still grips the pulleys.
Just enough tension that if you were turning a piece of rod, the band won't slip. I use a counter pulley with my set up, so I adjust the tension as little as possible for the work I'm doing. I find the counter pulley keeps up the torque when turning at quite low speeds. when not using the lathe move the band so there is no tension, so when you start her up next time there is lubricant all around the spindle. Personally, I turn the pulley by hand to begin with and add the oil then, also on my counter-shaft. I use ISO 22 Airline oil from Toolstation. It's about 8 quid for a litre. Pretty much the same viscosity as really thin engine oil.
I found this oil hits the sweet spot on my WW bed 8 mm Boley and Leinen lathe
I use the same oil when honing screwdrivers and the like
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
