Good evening, at least it is here in the UK.
I havn't had any dealings with watch servicing but have serviced a few clocks over the last couple of years.
My background is in mechanical engineering ( with the Royal Navy ) & electronic engineering. I became qualified as an electronic service engineering in 1984 & then worked as a engineer servicing & repairing Hi Fi equipment.
Then I became a photocopier engineer right up untill now.
During the 2020 lock down I was looking for things to do, and ended up researching & servicing a couple of 19th century French clocks I own. They had stopped working a number of years ago so I was pleased to get them working again, and have got a few English clocks running well since.
I just found this site & decided to join just because of the interesting amount of info here.
Regards ..... Gary
Welcome Gary. You have some interesting experience there. I'm looking forward to your contributions. I hope you get as much out of the group as I do.
Thanks everyone for the replies.
watchweasol, I love both watches & clocks but as time has gone by I have found that my close up sight has got worse. So I started buying pocket watches as the larger size is easier for me to see, I have approx' 35 wrist watches but can't see the time without putting on my reading glasses.
I couldn't even imagine trying to work on a wrist watch as they are tiny, but I do feel comfortable working on clocks.
There is a clockmakers shop not too far from me and in 2016 I took a Waltham pocket watch there for a service ( A pocket watch built in 1886)
The owner told me that he works on the clocks & his father works on the watches brought in. He said that when his father retires he won't be able to take on watches because " If you are trained to work on watches, then you can work on watches & clocks. But if you are trained to work on clocks, you can't work on watches".
I have a couple of clocks needing my attention at the moment ... a 1930's Garrard that i have cleaned & serviced and is running well at the moment. (Bought on the bay as serviced but when it stopped I looked in the back and could see oil dripping everywhere)
A 31 day pendulum wall clock that has run well for the last 9 years but has now decided it doesn't want to run.
And 2x 19th century French clocks that I stripped & cleaned during lockdown. They ran well untill recently but are again giving problems.
The French clocks are what I really want to get running properly.
Regards ..... Gary
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
