This video is a must-see for anyone into horology!
There's a lot to enjoy but one of the most fascinating sections of the video explains that the balance wasn't temperature compensated, so it constantly needed to be regulated depending on the current temperature. However, 300 years ago moving a regulator arm by hand would have been too primitive so they (Harrison) automated the process.
Seeing this blew me away. Enjoy!
Edited by VWatchie
Typo: "400 years" => "300 years"
Derek Pratt made a replica of Harrison's H4 in the last years of his life. The hardest part was making the pallets for the verge escapement, which were in diamond. How Harrison did it is a mystery; Derek told me he spent several years perfecting them, with modern machines and easily bought graded diamond powder at his disposal.
He also said that while studying the original, he found that you could remove the upper balance jewels and the watch would continue to run, and the upper pivot would remain centered in the hole. That hairspring looks ultra basic, but Harrison shaped it very specifically.
There's a fantastic book on Harrison called Longitude by Dava Sobel, well worth the read.
I hadn't heard about Derek Pratt so I made some research:
"Derek Pratt (1938–2009) was a highly respected British horologist known for his exceptional craftsmanship and contributions to precision watchmaking. He was considered one of the finest independent watchmakers of his time, often compared to George Daniels.
Pratt worked closely with Urban Jürgensen & Sønner and was instrumental in developing their detent escapement. He was also known for his intricate engine-turning (guilloché) work and innovative timepieces. Despite being relatively low-profile, his influence on modern horology was profound, and his technical skills were admired by experts in the field."
At Derek's memorial service, if someone had dropped a bomb 99% of the best watchmakers in the world would have disappeared. Amazing watchmaker and amazing guy.
3 hours ago, RichardHarris123 said:
I have read it, still have a copy.
An old book I was reading recently mentions Harrison building his H1 in Barton. I got curious so reasearched him more. Turns out he grew up in Barton not far from me. And tested his first chronometer clock on the river Humber, about 4 miles from my house. I courted my missus on the shores of the Humber estuary, watching the tides come and go 250 years later lol
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
