I have an old Elgin pocket watch and the stem pops out of the winding position on its own.
I want to buy a sleeve wrench that will fit this watch but there are so many to choose from. How can I select the proper set of sleeve wrenches that are likely to fit this watch?
Watch: 1935 Elgin Grade 315, Model 3, Size 12s (from serial number 35491021)
Case: Keystone J.Boss 10k Gold Filled Case (35053)
Furthermore, if adjusting the sleeve doesn't fix the problem and the sleeve is actually damaged, how can I locate a replacement sleeve, or sleeve/stem combination?
Thanks for any help.
Hi and welcome to the forum. Be sure to drop an introduction post into the "Introduce Yourself Here" section.
I would think that buying any sleeve wrench with at least 6, preferably 10 bits on it will have something suitable for your Keystone 12s case. Look for something like this and it is very likely to fill your needs for between $25 and $30.
In addition to being out of adjustment, it is possible the sleeve is broken or also possible that the stem's detent which locks it still in the sleeve is worn out and the stem needs replacing. Unfortunately, it is really difficult to measure and buy the right sleeve for a case or to find a suitable stem. Otto Frei lists a lot of options, with a chart of sizes and case manufacturers. Keystone was a huge company and they seem to be represented. https://www.ofrei.com/page441.html
If you can find a big assortment of sleeves on ebay (assuming your sleeve is the problem) on, you will be able to pay way less and have many to try out until one fits correctly. Otherwise, it is an expensive part and hard to find one that really fits as needed. This requires luck though because the assortments don't come up all that frequently.
Buying a similar Keystone case for parts is also an option.
Since your stem is popping out of winding on its own, I would think that a worn or broken sleeve is the likeliest problem. At a minimum you'll need a sleeve wrench to verify that. If it were just incorrectly adjusted, its behavior would probably be either sticking in winding when the crown is pulled, or never going into winding when the crown is pushed in. If the crown pops between positions and doesn't feel like it's always sitting on the edge of one position or the other, I would look at a sleeve or stem problem.
There are a couple of other forum members who know a lot about American pocket watches, and will turn up sooner or later with more advice.
If you take the movement out of the case and pull the crown in and out, do you get a nice positive click between wind and set positions? If it is too easy to pull or doesn't really stay in position, then a sleeve problem. But if the action does feel fine without the movement installed, maybe an adjustment problem.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
