Minute and hour hands only starting up after a few minutes?!
Hi all,
I'm currently working on a Omega Seamaster Cosmic 2000 166.128. Cleaning, lubrication and reassembly all done. All parts inspected and no broken/worn teeth on the gears. On the Timegrapher the movement runs excellent. Around 0 to -4 sec/d depending on position and amplitude between 245 and 275. Beat error 0.1 to 0.2. Lift angle correct at 52 degrees. I did multiple test rounds to make sure it is all good.
After testing I started wearing the watch and then noticed a weird phenomenon that I have not experienced before. After setting the time and pushing the crown back in, the seconds hand starts running Immediatly and correctly. I timed this for 20 mins with a stopwatch to make sure and still perfectly on time after this period, what you would expect from the reading on the Timegrapher. But, the minute hand (and I believe the hour hand as well) only start moving around 5 to 10 mins later. I checked it under a microscope and you can clearly see the minute hand does nothing and then suddenly starts up. After that it seems to run on time again, but ofcourse the watch is running 5-10 mins behind at that point.
I have tested if the hands run freely and this is the case. It also displayes the issue in different postitions of the hands, so I think this can be ruled out.
I then tried to read up on this problem and I believe I found two possible issues that could be responsible:
1. Minute hand is (too) loose.
2. Cannon pinion is too loose.
Before trying to fix either of these and due to the werid behaviour of starting later, but then running ok, I hope someone here knows what could cause this specific issue. If it's likely either one of the above issues or something else?
Hope someone can help!
Regards, SJ
Just found another piece of the puzzle. I compared the friction I felt when setting the time with another Cosmic 2000, and there is a BIG difference. That one takes a lot more ' force' to turn the hands. This also points to the cannion pinnion being loose, so I will attack that first.
Any good tips how to do this job without the special tool for a staking set? I don't own that (yet)... 🙂
 Make sure to dull the  nail clipper's cutting edge,       (  see photo )
 I cut two  half holes on cutting edges, so to secure the canon pinion in place,  Magnify the photo to see complete  hole the two half make when joined.
Then forum member canthus  added screws to the my design, considerably improving  it.
Here is a photo of the original one I made.
So,  go with canthus version, and file the two half holes on cutting edge, dull cutting edges. You furthure improve the design.
You get micrometer action by tightening the only screw on my gadget buy no preset limit on how much you tighten.
Good luck
Thanks all for the great advice and the pictures!
I did the job yesterday and it worked out great. There was already a small indent on the cannon pinion, which made it easier to position the nail clipper. For now inserted a screw driver of the correct diameter to make sure I couldn't tighten it too much. The hands are no longer slipping and the watch is running perfectly!
Another new job learned in the watchmaking journey 🙂
Thanks again everyone!
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
