So I've just bought a bow mill for $150us with all the cutters in relatively good condition, (Although I want to try making new ones at some point).
Just wondering if anyone had a recommended tool for bending the bows into shape?
I already have a self-made pair of bow-opening pliers, and I will get a pair of bow-closing pliers and some 2.6mm nickel silver wire when I do my next Cousins order.
image.png.848e05193dece931679fb4de3fe2d2e9.pngimage.thumb.png.ebe2159cb1f43af5126b7096f0a5ef20.png
I do not have a recommendation, but I will be following this thread with interest. I would love to see how the bow mill works. I have a set of bow closing pliers, the cheapest ones from Cousins but they have not been all that useful to me. I can't fit them into anything other than circular 18 or 16 size bows. Bows with other shapes don't really work with them and the lower jaw is too thick to fit between bow and case for anything smaller than 16 size.
Starting with wire that has enough excess length, wrap a tight spiral around a slightly undersize round bar or rod. Or just one and a bit turns for a single piece
You can then slit the spiral along the length of the rod and get as many near perfect circular pieces as you need of that size.
They would just need a slight twist to bring the ends back in to alignment.
(I've never made bows but have made coils and springs etc. using that type of technique).
Yep, that seems to be the way to go. I found this person using that method to make stainless steel bows: https://www.facebook.com/share/p/1H1qY3PBDY/. I'm going to use 3mm Nickel Silver instead, however.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
