Depends how much you want to spend ,Snap on and Knipex are good quality. Snap on mechanic's gear, Knipex is usually electrical stuff.  I have some old Draper drivers from when I started work, they're still in good condition .
I use mostly Wera now, good quality at a fair price. I can get quite abusive with drivers , and this brand stands up to me.
My favorite is PB Swiss, they aren't cheap, but hold up well, and have a parallel blade at the tip. Their hex keys are also the best I've used. I have Snap-On from my mechanic days, also good, but I find the blades are too thick for a given head diameter on European stuff.
Wera make non electrical drivers, A German brand made in Eastern Block countries now. A set comprises of drivers in the region of 5 - 6 quid each, nice big grippy handles with tough blades. Probably too big for some small clocks so their electrical types might be better.
Edited by Neverenoughwatches
I love online shopping, so convenient but I would really like to hold the screwdrivers to see how they feel.
I looked at the gun ones Tom, with apologies to all the good people of the USA, I  can't currently bring myself to buy any of their products.
Probably go for the PB Swiss, just need to know what sizes I need.
You could always make your own Richard, handles are available and square bar, o1 tool steel would probably work. You’ll need to harden and temper them though. The best screwdrivers I have ever owned and used were gunsmith ones. Maybe look for a local shooting supplier/gun dealer? Shotgun sizes should be common and be in the range for clocks I would think.
Maybe these guys can help and are local for you @RichardHarris123
https://www.henrykrank.com/finely-made-miniature-rosewood-handle-gunsmiths-turnscrews-1306p/
Tom
Edited by tomh207
Added link
I still have my screwdrivers that I used for clocks very handy to have these when it comes to screwing the movements back into there cases, they were flat blade and philips type.
Edited by oldhippy
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
