Resstarting a Three Barrel Smith Mantle Clock
wyleu
I would use horolene clock cleaner but be careful you most completely  cover the parts other wise it will leave a tide mark and you will never remove it, use in a well ventilated space. You need to get some steel clock pins, get a selection.
...waiting for the gasp when realising the cost of Horolene.... 🙂
Well it was going to be vodka but have you seen the price of that nowadays?
  • Haha 2
Nothing in Horology these days is cheap. It is very good for cleaning brass. You mention wire but I can tell you it is a steel pin, when replacing you need to bend it into an  S shape to prevent it from coming out. Another good tool to have is a pair of smooth jaw watchmakers pliers.
Edited by oldhippy
Couldn't have done it without the assistance provided here.
If anyone is in Sandbach there's a clock there that I have a certain responsibility for if they'd like a look . . .
The similarities are very strong.
Edited by wyleu
5 minutes ago, wyleu said:
An 1890 Joyce Tower clock driving two faces on St Mary's Church in Sandbach.
Thats pretty cool.  I've worked on a few very similar clock movements from various public buildings.  I'd quite like a look if I'm in the area
How does one adjust the The balance cock?
I'm nervous about adjusting it as even with the barrel at is' lowest end I don't want the mechanism to slip if the teeth don't engage.
It seems important to get enough engagement to ensure that the pendulum receives enough of an impulse to provide a decent degree of sweep but too much and it seems to bind as the four toothed spigot is lifting the chime mechanism.
I haven't seen a write up of how this is to be adjusted, or perhaps I'm looking in the wrong places.
The clock ran for 6 days with simply the going train, but is stalling with the chimes, strike wheels and front face mechanisms added, althou' I haven't' added the chime & strike barrels as yet.
    • I found a Trupoise in a flea market box of tools (🇬🇧car boot). I preferred the ‘8’ style tool until the moment I broke my new Omega rivet. The trupoise holds the arms firmly and I’ve become quite efficient… …and I just resorted to bending a balance cock. I needed a tiny bit less shake and it seemed the least risky of the other options. I held it between a stump and a fat stake while I bent the jewel end with my fingers. Honestly I don’t know how anyone would know by visual inspection.
    • It was about 4 years ago, one was 30, another 35 and 2 others came in joblots that I was after something else. 3 have ruby jewels and one has ceramic bearings.The most I've seen one sell for is £330.  In the uk i still see them sell occasionally for around £70.  I'm not convinced that the Trupoise has low enough friction on the pivots to be as good as a traditional tripod poising tool with unworn ruby jaws.
    • I have a Record 525 which is in a pretty bad way. From what I can see it is based on a cal 650 with an automatic bridge and centre seconds pinion under the rotor retaining stud.  There are additional bearings in the train bridge for the bottom pivots of the automatic works. Of these, on has come out of the bridge completely, one is a bit mangled with an egg shaped pivot hole and one is half in, half out. I've made bearings from scratch on the lathe before, but only for pocket watch pivots (i.e. considerably bigger than these!) and these bearings are either plated or not brass, to match the bride plate, I would guess. I could not find a bridge on eBay so I started digging. I checked new Ranfft site (not help, but the new one seldom is) then the cousins download centre but I could not find a document for a cal 525. I did, however find one for the 650 and, scribbled on the page are the words "= Longines 701". So, obvious next step (or so I thought) would be to check the docs for Longines cal 701 and then see if there is maybe a cal close by, based on that cal with a rotor. I checked, no 701 in the downloads section.  I did find some Longines 701 parts on eBay, which look similar to the 650 (i.e. the train bridge looks to be the same) but I feel I have hit a dead end. I have added some pictures that you may find helpful and I have photographed the entire strip down so I have more, if needed.  I feel I have few options: 1. Close the brewing holes up and reinsert the loose bearings. Close up the pivot hole on the 3rd bearing and hope that does the trick. 2. Make some new bearings (doable but tricky and will look wrong) 3. hold out for a 525 bridge to come up online. I get the feeling this is a rare movement though (all the more a shame it is in such a bad condition) 5. See if there is a Longines equivalent and either use that, or transplant the bearings from that bridge to the Record. Any help identifying the Longines equivalent (if it exists) would be appreciated. Any suggestions on the alternatives I have discussed are also welcome
    • Really you paid that little for a legit Trupoise?
    • Nailed it Andy 👍 It kinda was, but had a happy ending all the same.
