Finally dipping my toes into clocks... Seth Thomas 1302
I keep everything in branded boxes with the odd stuff in an others box. Just overs 2 years back into this I'm still sorting and cataloguing what I've got into a spreadsheet.
The worst I had was a A.zd.Mougin French clock where the anchor pivot had broken off, so they build up the pivot hole area with solder cut a hole in it for the shaft remainder and put the anchor back using the solder as a bearing for the shaft n not surprisingly it did not work for long. Bit of a mess to clean up. I have had others but this was a bit rough. -
Ithink the first thing is to clean the balance again Horolene or naphtha (lighter fuel) and start from there. -
A well thought out machine I did see a UTube demo of one and it did a good job faster than a lathe, it’s a case of preference I suppose. -
You have a versatile tool there. Three in one, a good buy.
