Decided to modify my bench today - Sharing before and after
Hello all, Just moved from US to Europe and brought some of my tools, well most of them. A friend gave me his Ikea desk that goes up or down. I told myself for the next few months it would be good enough. I didnt feel so safe not having borders around the desk to make sure parts to roll of fall off.
Went to the hardware store to buy either thin pieces of wood or plastic or something to glue/stick around the edges.
Ended up seeing a 120cm X 60cm wood top for 30 euros and was like... 30cm longer..  lets do it ! so bought it and came back home and intalled it. Feels so much bigger and better !
Eventually ill get one that i can cut off a little bit and add some space for my arms with a jigsaw but for now this is great !
Will get some clear silicone tomorrow to put around the edges where the top table and side panel meet to make sure there is no crevices. I have to add smaller pieces of wood in the front so when I work screws don't roll off on my side or at least help prevent anything from falling there, which happened a few times !
Would love to get a groove in but dont have the tools. Ill add a photo of a bench i think looks great !
here is a photo of before and after and if any of you have suggestions or Ideas to add to it feel free 🙂
Edited by Arigato
  • Arigato changed the title to Decided to modify my bench today - Sharing before and after
I love the desk's position in the room , great when you dont want to be disturbed. A sign hung on the door knob outside can work , though not quite as effective as your idea.
Haha good one 😉
we are living at a friends house until we find something else and fortunately it is quite a big European flat. 6 bedrooms.  That door opens to a smaller room where we and they put stuff in. That door is never used, there is actually 3 doors that opens to that room and only one is used.
6 hours ago, watchweasol said:
Hi. I think a serving hatch in the door so food and drink can be passed through .
I knew asking for suggestions was the right thing to do. That’s a great idea. Double wagyu cheeseburger extra bacon and a pint. 🍺
Seriously though it’s a tidy set up  but recommend some arm rests and seating so as the work level is across the upper chest region so a not to cause neck and shoulder strain. Ask Old Hippy. Bad posture caused spondylitis. Not good.
Oh the Desk is a electric desk so it goes up or down and I could actually using while standing up and im 6'2 so while this chair is comfortable enough for now, with a seat cushion, the desk is elevated to the right height for the work. Thats a good point you have, I might have ommited to add this info in my thesis lol. Arm rest might come sooner than later bu I might also make so cuts in the table top for the arm rest. I paid the top 30 euros and desk was given to me so wanted to try the bigger set up. Now some mods to make it even better will ensue .
Thank you for your imput.
Sorry for the typo keyboard is in 3 languages ;/
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
