Re-pivoting a wheel
On 3/29/2025 at 10:00 PM, luiazazrambo said:
I wasnt sure I left it in the green jelly in the cock. Clever you!
There us not much light for a good photo but I quickly placed the movement back temporarily in its case for a portrait.
Barnett & Scott - Hull
Made in my home town of Hull, 45 WhiteFriarGate. Which back then would have been the main shopping area, it had a shipping lane right at the top of the street. My son works just around the corner .I'll get you a photo of the shop next time I'm in town.
Edited by Neverenoughwatches
9 hours ago, luiazazrambo said:
Thanks, with this you answered my next question as when to turn the pivot, I assume it also helps to do the length/adjust the end shake with this as you cannot be 100% certain how deep exactly you can push the new bit down.
Yes just turn down the part to the required diameter heat the pinion but not cherry red press fit part quench before heat transfers to new bit then turn pivot and shoulder to correct length for end shake.
I would recommend doing a test piece before doing the arbor, drill a hole in a bit of round bar of approximately same diameter as the pinion turn a bit of steel to required size heat and press fit then quench, that will tell you if the hole size is correct & roughly how long to heat & most importantly give you confidence to do the proper part especially if you do it more than once.
Dell
WhiteFriarGate where the clock was sold from . In the 70s, 60s, 30s, and late 1800s when the shop was still there.
16 hours ago, Dell said:
The holder the blued steel is in looks like a gun shell, and it looks old so probably good quality blue steel, some of the new stuff is rubbish.
Dell
This video maybe of help to you to give you an idea of what’s involved.
https://youtu.be/-eYvYYc-8dc?si=K_6dU2PifHeuT7An
needless to say it’s not how I would do it or suggest you do it but it’s just to give you an idea of what’s involved.
Dell it is a cardboard tube. My blue steel was in something very much like it and yes the steel is as hard as hell.
    • I found a Trupoise in a flea market box of tools (🇬🇧car boot). I preferred the ‘8’ style tool until the moment I broke my new Omega rivet. The trupoise holds the arms firmly and I’ve become quite efficient… …and I just resorted to bending a balance cock. I needed a tiny bit less shake and it seemed the least risky of the other options. I held it between a stump and a fat stake while I bent the jewel end with my fingers. Honestly I don’t know how anyone would know by visual inspection.
    • It was about 4 years ago, one was 30, another 35 and 2 others came in joblots that I was after something else. 3 have ruby jewels and one has ceramic bearings.The most I've seen one sell for is £330.  In the uk i still see them sell occasionally for around £70.  I'm not convinced that the Trupoise has low enough friction on the pivots to be as good as a traditional tripod poising tool with unworn ruby jaws.
    • I have a Record 525 which is in a pretty bad way. From what I can see it is based on a cal 650 with an automatic bridge and centre seconds pinion under the rotor retaining stud.  There are additional bearings in the train bridge for the bottom pivots of the automatic works. Of these, on has come out of the bridge completely, one is a bit mangled with an egg shaped pivot hole and one is half in, half out. I've made bearings from scratch on the lathe before, but only for pocket watch pivots (i.e. considerably bigger than these!) and these bearings are either plated or not brass, to match the bride plate, I would guess. I could not find a bridge on eBay so I started digging. I checked new Ranfft site (not help, but the new one seldom is) then the cousins download centre but I could not find a document for a cal 525. I did, however find one for the 650 and, scribbled on the page are the words "= Longines 701". So, obvious next step (or so I thought) would be to check the docs for Longines cal 701 and then see if there is maybe a cal close by, based on that cal with a rotor. I checked, no 701 in the downloads section.  I did find some Longines 701 parts on eBay, which look similar to the 650 (i.e. the train bridge looks to be the same) but I feel I have hit a dead end. I have added some pictures that you may find helpful and I have photographed the entire strip down so I have more, if needed.  I feel I have few options: 1. Close the brewing holes up and reinsert the loose bearings. Close up the pivot hole on the 3rd bearing and hope that does the trick. 2. Make some new bearings (doable but tricky and will look wrong) 3. hold out for a 525 bridge to come up online. I get the feeling this is a rare movement though (all the more a shame it is in such a bad condition) 5. See if there is a Longines equivalent and either use that, or transplant the bearings from that bridge to the Record. Any help identifying the Longines equivalent (if it exists) would be appreciated. Any suggestions on the alternatives I have discussed are also welcome
    • Really you paid that little for a legit Trupoise?
    • Nailed it Andy 👍 It kinda was, but had a happy ending all the same.
