Where have all the mainsprings gone...long time passing...
25 minutes ago, RichardHarris123 said:
Make/ modify but yes, sad. It's not just mainsprings, all parts are getting rare . In the future, the only option will be to make your own.
Method for making some things is well established (staffs, wheels...) but I know of no established method for making a mainspring.
Pretty sure nobody is making mainsprings for vintage watches
you need to define vintage watch?
one of the interesting problems of mainsprings would be is look at the GR catalog in the back of the mainsprings listed by size. You go through each of the pages counting how many mainsprings are listed you find that at one time there were a heck of a lot of mainsprings. the problem is if you stocked all those mainsprings how fast would it take to go through them?
Then of course the Swiss have changed the manufacturing to only manufacturer for what they currently need. mainsprings were probably be like hairsprings no longer made in a generic fashion but only made for the specific consumer because I don't want to stock stuff that's not going to turn over instantly.
But that doesn't mean you can't get mainsprings. Many years ago there is a crisis over American pocket watch springs from the Swiss and what happened the material houses pooled their resources to place orders big enough that the manufacturer did manufacture  American pocket watch Springs. Unfortunately they did not purchase a lifetime supply of those Springs.
then I'm assuming if the demand is high enough like for instance Rolex somebody will manufacture a mainspring which is why we have aftermarket mainsprings.
But you really don't have to worry anymore if your vintage mainspring is blued steel no problem it can be? I'm going to give you an image from the discussion found at the link below apparently there's a procedure for blued steel Springs to bring them back to life so as long as is not broken no need to ever change the mainspring? although if it's not a blued steel spring I guess you're out of luck.
https://mb.nawcc.org/threads/new-to-pocket-watches-new-main-spring-question.216027/
because you need heavy equipment. if you are making individual spring is you need a way of rolling out the wire so you need a rolling mill then you'd need a method of a controlled furnace and of course the right steel. It seems like there should be something in one of the vintage books I know I have books and talk about how to make a new hairspring it seems like the principal should be similar just bigger?
46 minutes ago, Kalanag said:
See here:
Making Hairsprings
I‘s a big one, made in a so called „home shop“. The procedure should be applicable for main springs.
Impressive! I think you are right.
Yeah, I read that on NAWCC the other day.  Perhaps that is what got my mind to ponder the topic.
    • Tool collection, yes, hording no, I  have an aversion to anything not being used.  In future, reassemble the movement as far as possible, bag and label what it is and what's missing.
    • Welcome to the forum. You don't need the crown to remove the stem as you can just pull it to the 2nd position to access the dimple. Just grip the tube with a pair of pliers and pull it out. Measuring for a replacement could be a little more difficult for a beginner so maybe best just getting an assortment. For the crown you'll need to measure the diameter of the recess where it sits, the outside diameter of the tube along with the thread size of the stem (think it's 0.9mm) Need a closer look at where the crystal meets the case, it looks like what's called an I-Ring and should just push out from the back, preferable with a press. You can then measure the diameter and thickness of the crystal to get a replacement. Not sure what you mean about cleaning and oil solution? Edit Should have asked if you've checked the movement still works?
    • This would mean that if the reaction doubles then I guess we reduce the time by the opposite?  Or simplistically in the case of watch cleaning fluids nothing it is really achieved by elevating the temperature other then bad things happening. The only place I know of and watch cleaning were elevated temperatures works is cleaning the band and/or bracelet. It's amazing how much biological material gets caked on the bands and elevating temperature with ultrasonic works well of course you using a proper cleaning product which is different than what you're using the clean your watch movement.
    • Never ask anyone into watchmaking what to keep! As Andy points out we probably all have an aversion to getting rid of potentially “useful “ things 😂   natural born hoarders and tool collectors, every single one of us 🤪🤣   Tom
    • I'd say just keep everything but I'm probably classed as a hoarder. If you come to work on either of these movements again the parts could come in handy.
