Who loves Aliexpress
By HectorLooi · Posted
Hi! Welcome to WRT. I launched a particularly springy battery clip into space last week. Usually I'd listen for ricochets and search in the area where it landed. But in this case, I didn't hear a thing. Spent 3 days searching for it but nothing turned up. Probably have to wait for SpaceX to go up and retrieve it. From your moniker, are you an endodontist (dental) or endoscopic surgeon? -
I am really pleased I have managed to restore this movement, after a good clean and installing a new mainspring she is running like a charm! I now need to source a winding stem and a watch dial face but don't know where to start looking! Help Please! I believe the movement is listed here under Early Omega Wrist Watch Movement: https://www.vintagewatchstraps.com/movements.php
Welcome to the WRT forum and good luck with your forey into horology.
Hi all, I'm in the position to take over a Boley lathe. It's 8mm with a cross-slide and faceplate I wanted. Apart from making balance staffs and winding stems, an important goal would be repivotting and drilling out worn pivot holes to rebush (oval ones making round again). There is however no tailstock included with drillchuck or even just one with simple collets. What are my options? As it's also no WW, finding compatible tailstock will be next to impossible (and then there is the problem with alignment). I know there are people doing it freehand but as a novice with not to steady hands (understatement) this seems extremely difficult. It would be used for wristwatches and clocks. Kind regards
By RichardHarris123 · Posted
Hello and welcome from Leeds, England.
