Hello All,
I am having difficulties removal the Chinese movement from Kenneth Cole watch, A126-12 KC1920.
The movement is inside a plastic enclosure/frame. I have removed two screws (green) to no avail and as you can see there are two more (red) but unable to unscrew them as besides them a metal pin, which I suspect is preventing me undoing ones.
I would appreciate if someone advise/point me on how removing it.
P.S.
The movement has some issues with the second hand constantly loosening/falling off. I will try to fix this or use one as testbed to learn disassembly/assembly. I believe the movement is Seagull ST-1812 (TY2661)
Edited by SAMyMAS
Revised
So with tab on the back then it must come out of the front.
You do know these screws are to remove the dial?
You turn them to the flat frees up with the dial pin.
Edit
Just realised what the red and green referred too in your original post as the arrows weren't obvious being so fine.
Edited by AndyGSi
Spot on. The movement came out at the front with the dial in place. I didn’t realised the pins were from the dial and certainly did not know about the screws function in securing the dial release. Managed to remove the dial but broke one pin though and damaged the another. This shouldn’t be a problem, I have new spares to install. Thank you @AndyGSi for your continued help.
