After a good long learning curve I have become confident enough to start buying and fixing up some of the watches I have always wanted myself.
I bought this lovely (albeit frighteningly heavy)  Tag 2000 Exclusive Chronograph with a 7750 movement inside.  It had a few problems…. The biggest one now is the bezel.
When I got it the bezel had a lot of play and clicked unevenly.  I removed the bezel and found that the bezel spring that sits under the bezel was broken and that one of the little bits that sticks up had snapped off.  I ordered a replacement from Cousins - I believe they are not original parts but it was listed for this watch.
I have put the new spring in (pretty sure correctly!) and now find that the pip does not align at 12 o’ clock but is off by about 1/2 minute (about as bad as it can get with 60 clicks)
Is there something I can do - I found something somewhere about gently filing the notches on the spring but that sounded like a recipe for me destroying the new spring I just bought.  Is this usual and do you have to tune it -  and how is that done properly
I am also not happy with the stiffness of the bezel but am unsure how to tighten it.  There is an another little octagonal wire spring that sits inside a groove in the bezel. This I believe is what affects how hard it holds to the case and how tight the bezel is - Can this be manipulated to make it better or should it be replaced?  Not sure where to find that either (would have expected it to be close to where I bought the other spring but nothing there….)
39 minutes ago, AndyGSi said:
Some models have various holes in the case to set the spring in different positions to adjust the alignment of the bezel.
There was just 1 hole in the case and only 1 way it could be placed.  I have worked on a Seiko that had a similar spring with 2 holes in the case under the bezel and that one could take the same spring in 2 different orientations - I guess it was symmetrical anyway….
That Seiko also had a much tighter grip on the bezel and it felt a lot less likely it could get pulled off. It was however a much harder job getting that bezel back on
I bought one with the part no: T49740 - Now I look at the site I can't see CN2110 (which is what is written on my caseback) on the list of supported cases. I think I read somewhere else it was the same? But I guess not....
Putting it side by side with the old one I took out it appears identical - The seller was the original owner but I guess they have kept secrets from me about what was wrong with the watch - I needed to change the oscillating weight bolt as it was broken causing the weight to not spin freely enough to keep the watch going. I guess that and the wonky bezel could have been the subject of failed repairs in the past
Edited by ColinC
typos
That was going to be my next question how it compared to the original and was it a 3 or 4 click ratchet.
Does the Cailbre 16 have the same weight and assembly as the 7750?
I am not sure that the spring in there when I got it  was the original / correct!
I compared the old and the new placing them on top of each other and I could not see any difference (apart from the fact that 2 of the prongs were broken on the old one).
The photo here is probably better than anything I will take
https://www.cousinsuk.com/sku/details/tag-heuer/t49740
I will need to open the watch again to be 100% sure - but I recall that the watch is a 7750 and not a Calibre 16. The oscillating weight says Tag and not Calibre 16!.  What difference would this make to the bezel?
This was in relation to your comment about needing to change the weight.
I didn't change the weight but had to replace the bolt that holds the bearing to the weight - Mark makes the job look so easy!!!! (I really struggled and annoyingly put a scratch on the weight)
I decided to have a go at manipulating the  bezel ratchet spring and gently bent up all the 4 prongs evenly - after a few rounds of doing that the bezel is now lined up properly and the click feels much firmer. Happy with the result!
    • This is probably the single most important point. One of my best friends, 48 years old at the time, suffered a massive stroke about 15 years ago. He barely survived, but his life was never the same after that. If you had asked me back then to guess which of my friends might have a stroke and nearly die, he would have been the very last one I'd have picked. He was perfectly healthy, played tennis three times a week, ran a successful business, was full of life, and had a wonderful wife and well-behaved teenage kids. The harsh truth is, we never know when it’s "game over." @Mark, I truly wish you a long, happy, and successful life. But have you given any thought to some kind of backup plan for WRT in case the worst should happen? Is there anyone who could keep the site going? If you can reassure us in some way, it would mean more than a lot to us!
    • Update: The demagnetization only helped temporarily, maybe it pulled the wheels into a position where they liked each other. I have to adjust the sub second hand as it is a bit angled upwards and catching the minute hand stopping the whole movement but before this happened there were some wild deviations. HWGIKE#58 Alarm clock, cooked in hot cleaning fluid and oiled gently. This is a movement so I count it. 🙂 A while ago it tried to fly away one day, it was on my windows sill, we had strong wind the curtain flew like a flag and doing so encouraged my clock to do the same...  went out and ended up on the roof above the entrance door, its door in pieces but the clock itself suffered no damage otherwise. The original glass was already broken when I received it I still have the bottom part in two pieces. The new "glass" is acrylic. It also had a paper in the back in the case inside but it disintegrated, I still have a little bit of  piece of that too.     HWGIKE#59 Durowe 870 / Times M84 This particular instance is a D870, when I saw its worn out contact pin I thought that it must be a design flaw, and here we go: https://17jewels.info/movements/d/durowe/durowe-870/ An incredible movement again where the balance wheel drives the train and has two magnets one for the balance wheel/coil and one for the pallet. The magnet for the pallet is basically the "draw" one direction. The coil is about 1.8kOhm and one end is in contact with the main plate and the other end is soldered to a contact pin which is insulated by the means of putting it into a jewel and this contact pin is rubbing against a wire getting the energy/impulse as it is passing. Behind the contact pin there is an "impulse jewel" not sure why is it there... the wire seems to hit the impulse jewel first then the contact pin but maybe it is there only for insulation purposes? I was almost certain that the screw holding down the battery - (minus) clamp had no insulation washer.. i only noticed the green stuff around it coming from battery leakage... anyway the + and - had a shortcut which took me a while to realize.. had to fabricate one insulating washer on my own. The jewel settings were dirty but not it is all cleaned and oiled. The contact pin might work for a while but I am sure it has a short life. It is a front loader the whole thing is held together by the case so it is not possible to regulate it without putting it all together and taking the movement out of the case again, very inconvenient. A wonderful movement but not made for eternity only for the consumer market.
