How to properly remove the hands of a GMT 126720 if stem is broken and stuck inside
Cousins don't have the correct movement variation for the OP. Edit Just realised that although the date is at 4, so is the crown, so Cousins do have the correct variation, it's just a matter of which one is needed H1, H2 or H6.
Thanks OH. I'm servicing it, rather than buying, so it is what it is. Interesting clock though.
Hello and welcome to the forum. As I recall the Ronda 515 is a replaceable quartz movement , available from Cousins at approx £10 I have added the technical sheet for you. TA_512_513_515_de_fr_en.pdf -
One can only concur with the previous posts, I have quite a lot of redundant watch and clock bits. Never know when you might need them. -
That is what I was expecting to see regarding ornaments it's Atlas carrying the globe and two Pheme Goddess at sides. Dutch striking is a hammer striking one of the bells on the hour and another hammer striking another bell on the half hour being a different tone. It certainly look as if parts are missing, be careful as many of these clocks are not as old as you think.
