Any ideas how to make this dial usable?
I bought a cheapo eBay watch which I wanted to try and “restore”. The movement is a Tissot 27B-21 which runs and looks very clean. The case and dial are a different matter!  My main aim is to practice on the movement and try to get it running as well as I can.
I’d like to end up with a usable watch at the end but I fear that the dial is a lost cause. It’s badly stained and scratched. One nice thing though is the old style Tissot logo which matches the logo on the inside of the case back. I know that cleaning dials is generally a non-starter for fear of making them worse; but it’s hard to imagine I could make this much worse.
Does anyone have any suggestions as to how it might be worth trying to clean this?  I was also wondering if I could go drastic and strip the lacquer completely, leaving the gold hour markers and logo intact. Sorry if this is heretical talk but, for me at least, the current dial is not usable.
I can’t tell if someone has had a go at cleaning already between the 8 and 9?
Thanks, Bill
59 minutes ago, AndyGSi said:
I'd start with saliva on a cotton bud and go from their.
That's what I do. Saliva works well (at least mine does but that might be due to the alcohol content 🤣 )
Then I would try naphtha (lighter fluid) , then IPA - but only the tiniest amount on the very edge to start with to see the effect.
  • Haha 2
Thanks @AndyGSi @mikepilk
I just did a quick test and the saliva was certainly removing some of the staining. The temptation to really go for it and use too much pressure is almost overwhelming but I’ll keep at it and see where we get to.
Rather than rubbing with pressure, you’re far less likely to damage the dial if you use a rolling action to clean it.
Wet a q-tip or similar shaped foam swab and roll it over the surface. It’s slow, but it’s very gentle.
I hope that helps,
Mark
I hope that helps,
Mark
Thanks - yes that makes sense. I’ll try that.
So this is where I’m up to. Just using saliva and a piece of paper towel wrapped around a small plastic stick.
IMG_0389.thumb.jpeg.8a757136818b742fbfaf78544cb28373.jpegIt’s still not a thing of great beauty but better than it was!
I’ll go over it again but it almost feels like all the staining is in the top layer of lacquer, so it might be interesting to try and remove that without destroying what’s underneath. Somehow 🫤
  • Like 5
 Ye thats as far as salivamatic works, unless you wanta try putting saliva on top of one stain only, give it some time to  peneterate  deeper.  Worth a try on one stain.
Typically with dials it's recommended not to do anything at all because typically they don't do well to anything especially if they're painted dials. If there are enameled dials like found in American pocket watches then they can go in water and all sorts of cleaning and will clean up quite nicely. Or some American pocket watches use engraved brass dials filled in with wax or something like they did with clock dials and then silvered. With fee is you can strip off the lacquer and dip them in one dip silver cleaning brightening solution. That actually works really well and then unfortunately you have to lacquer it again because with the silver exposed it will tarnish. Seeing as how you are able to clean up or dial the way you did you may build a try some of the liquid silver tarnish remover. But whatever you do you typically want to be careful as even if you think you know what you're doing bad things can still occur. Which would result in either finding a replacement dial or sending it out to be refinished after somebody on your part of the planet that does that kind of thing.
Yes I think you’re right. I gave it one more go but it seemed barely to make a difference so I think it’s time to restrain myself and stop!
@AndyGSi @Klassiker - stopping while I’m ahead is definitely the way to here!  Now I need to figure out what to do with the case. Most of the chrome has flaked off and is showing the base metal - brass I think. Polishing wheel and electroplating à la Nekkid Watchmaker needed! Maybe one day.
Final result:
14 hours ago, AndyGSi said:
How bad is the case and have you looked to see if there's anyone in your area that does plating?
I haven’t checked locally for plating but I’ll take a look.
The case is pretty rough I think, so not sure what I could do with it. If possible I’d like to try and polish it up by hand - perhaps taking it back to the brass - and then see whether I could achieve any kind of plated finish for a fairly low cost. Maybe just nickel plating?
The crystal is also cracked and scratched (the image of it is after having a little go with polywatch), and I can’t figure out how to remove one of the spring bars. It is different to the one on the other end and doesn’t seem to have anything to get hold of with the removal tool.
I can see a couple of service marks in the case back so I guess it has been looked at a couple of times at least. From the serial number it seems the watch was made in 1956.
IMG_0402.thumb.jpeg.a399623c36d99cb0d7b399f95acce30d.jpegIMG_0403.thumb.jpeg.c3dc3898bc7338fa0e7a85a67a7b3910.jpegIMG_0404.thumb.jpeg.091620dadb86d7f15b51c790d14a7c25.jpegIMG_0405.thumb.jpeg.657764812d4050ed139d54bc00c0edb0.jpegIMG_0406.thumb.jpeg.563b7fdefd3ae5fcccf8304d0cc8b58e.jpegIMG_0407.thumb.jpeg.3cb9b68b5081410c0a2dff5de6582b98.jpegIMG_0408.thumb.jpeg.a19caa28da98d56b8bedc1b7593acf7b.jpegIMG_0409.thumb.jpeg.3757d05f0c53e56ee10488edd6e83498.jpeg
Edited by Bill2024
Typos
2 minutes ago, Bill2024 said:
The case is pretty rough I think, so not sure what I could do with it. If possible I’d like to try and polish it up by hand - perhaps taking it back to the brass - and then see whether I could achieve any kind of played finish for a fairly low cost. Maybe just nickel plating?
It's quite a lot of work to get it back to brass and replate with nickel. The finish you get on the nickel will be the brass finish you achieve - nickel does not fill any defects. So you need a polished finish with no defects. I plate with copper before nickel as it can be plated thick enough to fill pits and defects. But then I have to polish again before the nickel.
You can do home plating quite cheaply, there are plenty of Youtube videos showing DIY nickel plating.
  • Like 5
Thanks, that’s interesting about using copper first. I’ll  try and get the case as smooth as I can and then try copper and nickel.
Is there anything recommended for doing the prep if the case by hand? I have some of the eze-lap diamond paddles which may work for the initial stages (the finest is 1200 grit), but I guess I’ll need something finer to get a decent polish. Thanks.
It's called a copper strike and has a few different functions. Depending on what the base metal is, and it's condition, a copper strike can improve the top nickel plate adhesion and gives the base metal an overall better finish to start the nickel plating process. It's main reason is help visually check that the plating process is working ok, to find surface defects before the nickel plate is added. If something isn't right, the copper undercoat is easier to remove than the nickel.  If the copper strike looks good and is adhering then all should be fine to carry on with the top nickel coating.
Use cheap emery sticks, half-round and flat, starting at about 220 grit.
Hold the case firm in a vice between wood or plasic, best are those that you can swivel to all positions.
Frank
N.B. To strip the chrome, put the case for few minutes into hydrochloric acid. If it is still there after 30 minutes, it is most probably nickel.
Edited by praezis
Some might find this idea useful. My son owns a bar, which is handy.
If you have lots of different cork sizes like me ( I don't drink ) you can usually find one thats a good tight fit inside the case. If not , find one that's close undersize and bang a wedge down the middle of the cork to expand it, like wedging a handle for something.
I also use corks for sittings domed acrylics on when polishing them. Stick a sponge on the cork end and squeeze the crystal over it.
Like so.
  • Like 5
 As I understand it, the main reason for a copper strike is that copper plates better over most surfaces than nickel and provides better adhesion for the nickel. Not for showing defects, though it would do that. As the layer is very thin it doesn't require further work before further plating.
If plating on well prepared brass, I don't think a copper strike would be worth the effort.
I usually do a much thicker copper layer to fill defects. This does need refinishing back to shape. If doing this you may need to protect some parts such as threads, as too much copper build up can block them (as I know from experience 😲)
You can grind the nickel away but it's hard work. I use a nickel removing solution and reverse electrolysis - takes a minute or two.
I like the cork idea Rich. I have lots of corks around (as I do drink 🤪) and will be doing that in future
Edited by mikepilk
Frank
Emery sticks sounds like a plan. It might even be time to get Dremel and some polishing wheels.
That sounds interesting. Is there a particular setup you use to do this? Is it just reversing the polarity (nickel plated item on the negative terminal) and a copper (or similar) electrode on the positive, all in a non-corrosive solution
Like so.
I love that idea. I don’t really drink either (and the kids don’t own a bar) but I am prepared to take one for the team to get a few corks!
Edited by Bill2024
Using wheels on the Dremel, the problem is nickel is hard and brass soft, so you need to be quite aggressive to remove the nickel, but be careful not to damage the brass. I've done it, but it's a lot of work. Much easier to use reverse electrolysis. If in the UK I buy Nickel Stripping Solution from
https://youplate.co.uk/products/nickel-stripping-solution
It's a mixture of mainly strong sulphuric acid  - you can find the recipe online to make your own.
This guy uses vinegar, seems to work. You need to keep checking as too long and the brass will be pitted
    • Hi there Mathew, welcome to the forum.
    • I often think about painting clear varnish on the coil.
    • I hate this battery release design in Ronda movements. It's an accident waiting to happen. One slip and the coil is gone. I wonder if it's a deliberate design.
    • so let's break this down the words restaffed balance wheel correctly would mean no distortion at all on the balance wheel. Which can be done but often isn't. Oftentimes balance wheels end up and times particularly discussing a bimetallic all bent up like the one in this discussion. If the balance wheel is out of round you definitely get a poise issue. You also get an issue if somebody pleases and out around balance wheel and then you fix the out of round now the wheel is poised incorrectly because somebody didn't physically make sure the balance wheel was correct in the first place. Yes people really do poise balance wheels that are neither flat or round it's quite annoying and then it typically with anything vintage there's an extreme likelihood of timing issues. Like the fun I had yesterday the wall thumb was 400 seconds fast and had a 202nd positional problem. So yes it's extremely common on vintage watches you're going to have things to fix from prior inappropriate repairs typically and it depends upon how it nitpicky you want to be here. In other words if you are statically poising the definition of poised would be if you give the balance wheel of push it will rotate eventually come to a stop and it will not rock back and forth at all is considered perfectly poised. Typically when I poise I don't worry about that I will let it rock back and forth because it still going to be within 15 seconds typically. Now the problem with statically poising absolutely perfectly is that it does not take into account the hairspring. This is why ideally if you are really obsessed you statically poise until your close and then finish with dynamic poising. This will take into account the hairspring collet that's probably not a poised collet. Yes Hamilton had another companies had poised collet's they hairspring itself affects the poise so for absolute perfect you have to dynamic poise. So the suggestion has been that it absolutely poised dynamically done balance wheel will not be statically poise absolutely perfectly.    this is an interesting one? In the United States of America over a time span and I don't remember the exact but it ended in the 60s there was a tear off on watches to protect the American watch industry. I've read the books on the tariffs specifications it would bump up the cost of better watches to making them expensive. This is why you will often see a nice Omega watch for instance that was regulated was adjusted and was still keeping really good time will be marked not adjusted. Because the quantity of jewels each jewel bumped up the cost adjustment adjustment and variety of positions bumped up the cost so a huge percentage of watches imported into this country will be not adjusted but they were adjusted at the factory it's just a terra thing then I suspect that even the cheapest of watches probably were somewhat adjusted because if they had zero adjustments I have no idea how bad the timekeeping would be? It's one of the problems of we don't actually have numbers of what the watches really should be doing we only have numbers of timekeeping basically when timing machines exist or for things like railroad grade watches where they absolutely had to know what the timekeeping is doing. So railroad timekeeping specification in this country is of watch Dependent up has to be within plus or -30/2 per week. Which if you compare it to the specifications of chronometer grade will ask which I think could be up to six seconds a day is better than a Rolex. this is one of my amusements at work. There we have that really nice which he timing machine full automatic microphone we look at every single watch and six positions and my boss once the watches all the keep really good time. So basically the watchmakers have learned to let the boss adjust the watches it seems to make him happy and we can do other things like service watches. So yesterday's fun on the 18 size Waltham to get the 400 timing down to think he got it down to 15 seconds it might've been better than that the Delta was still might've been within a minute much better than what it was before but still took more than an hour of time. When we don't specifically charge for this we charge for servicing of the watch we do not typically charge to make your watch keep time in multiple positions so yes it wastes a lot of time unless you're getting paid for it where it can definitely eat up a lot of time to fix vintage watches that I've had interesting repair histories. sorry I don't remember the brand name we once had a watch that was one of I take 1000 it actually was engraved number or something of something in other words it was a very expensive Swiss watch and I believe there was at least one shim under something. I always think of at the factory level if you have to place a shim to me it's a sign of poor manufacturing but there was a Swiss watch a nice watch that had it done. Of course what it may also be a sign of limited quantity of watches where things or adjusted at the factory we end up with interesting problems and I will pick on American pocket watches again with interesting repairs that can happen? For instance pocket watches dropped balance staff is broken possibly the whole jewels are broken and sometimes cap stones get broken. or worst-case I had a Hamilton 992 it actually had little notches taken out of the main plate I always wonder if it got hit by a train and things were dramatically bent in this watch somebody had ground the pallet fork bridge down to accommodate the balance wheel because the balance bridge had been bent to insane proportions it was bent so much it was no longer up and down in alignment so I always wondered if this particular watch got hit by a train. With its ultimate repair it would've been better to just replace the whole movement but instead we cannibalized another movements to replace all of the horribly mutilated parts. Now back to not watches hit by a train while somebody was crossing the railroad track. If the balance jewels are broken they are replaced but the same problem like we have on this group where do you get replacements? This means people in the field will get creative if they replace things with size differently than the original things will change. In other words the total length of the balance staff conceivably will change because they've changed the jewels and they're not properly sized. Then there's a problem of replacement balance staffs I personally have often theorized in the case of  bestfit  that they deliberately made the staffs oversize so the watchmaker can reduce the size. But what if you don't have a lay then what happens? A for instance the Hamilton 992B only has one balance staff as it's of friction staff but often times the friction staff doesn't fit because the replacement staff is slightly oversize which should be impossible but it happens. Often times I have to go through an assortment of staffs to find one that fits because I don't feel like reducing at the size to fit. More common though would be staffs with pivots that are too long and if the watchmaker does not have a lathe again how do they fix that problem well undesirable for us that have to deal with it down the road so an ideal perfect world the adjusted by the factory to whatever the specification was at the time and on a seven jewel American pocket watch it's not going to be railroad timekeeping. If we replace the staff in a proper fashion without bending or distorting anything the watch should keep time within the specification when it was originally made except of course we don't know what the specification was and they definitely did not have timing machines when this watch was made. If we replace the balanced staff with a factory original factory staff and everything should fit perfectly if the jewels were broken and we used factory jewels everything once again would be perfect. Although if you look in the parts book typically for American pocket watches for certain parts they recommend sending the entire watch or parts of the watch back because American watch manufacturing at least until the not sure exact date but sometime past the 20s definitely by the 50s watches were made in batches which is why everything has a serial number and the tools over the course of the batch tend to wear a little bit. So conceivably something made at the beginning and the end of the batch may not fit without adjustments. Plus of course there's variations in parts I like the pic on Elgin because they have one balance staff that comes in four different size variations and then a whole bunch of pivot variations all with the same part number so yes and an absolute perfect world which doesn't exist changing a balance staff with everything factory new would not require poising or truing the balance wheel because everything should still be perfect. But unfortunately in the 100+ year life of your watch things have happened. If you want to grasp that go back and start on page 1 of this discussion as the balance wheels in this discussion have had issues they're not flat the probably out of round there were issues with the jewels there is issues possibly with the staffs. Oh and yes apparently there's a donor watch and if the donor watch is not within a very close serial number range of the original watch it will have very likely sizing differences especially for anything related to the balance wheel because all the vintage watches were adjusted individually in the factory. If you look at a video on I can find it if you want to watch it on YouTube from I believe the 30s where you will see on escapement related stuff every single watch is adjusted which is why you can't just grab the balance wheel from one watch shove it into another one as they were adjusted at the factory
    • I see a lot of URLs pointing to 1drv.com which appears to be a CDN for OneDrive.
