Welcome to, the forum, enjoy.. I suspect the thread is a reverse thread hence it has been stripped by tightening the screw not undoing the the screw.. The only way to fix this IMO is to find a donor movement I’m eBay.
If I were you I'd be very pleased with the result so far, and quit while I'm ahead.
By rottobotics · Posted
Outside diameter of the screw threads is about 0.7mm. I also have a 125W soldering iron and a small butane torch. Though I currently only have solder for electronics, it looks like I would need silver solder for something like this -
What options do I have? This is more of a practice movement, since there are other issues as well. I'm open to options that might not be acceptable to a customer. Threads on the screw look good. I have JB Weld and Loctite 242.
