Long time lurker, rarely post.  Just completed service on Landeron 48. Pegged, cleaned in L&R, oiled, new MS, etc.....  Was running great (although still needed very minor adjustment).  Had to have an Xray on my hip the other day. I did inquire about magnetic field from machine. No worries I was told..... Anyway now this thing has picked up about 15 min per hour fast.  I have demag. 3 times, last time with caseback removed so I could set bare movment on tool.....  I see the 2 outer coils of the HS touching.  So it's either magged or possibly some oil migrated to where it shouldn't have.  Although I oil very sparingly...... If less is more, than even less is my approach....  Any thoughts on where I need to proceed from here???   Obviously I gotta pull the balance and clean or love on the HS..thoughts anyone..?????
Thanks!!
John
The MS used was a Magistral Super labeled Landeron 48 and 3530 1.35 .145 380 12
Initially it looked really good on the TG. I use a Weishi 1900.  I  did change lift angle to 42 and set rate to 18000.  Next problem is the Weishi is flaking out.  Still under warranty until late June.  IF I COULD FIGURE OUT HOW TO FILE A CLAIM!!!  Transducer is flakey!!!
Yes the balance is coming out tonight to see what is up with HS.  Just strange that it started right after the x-rays....
This is my favorite vintage piece.  Baume&Mercier 18k chronograph  Suisse.......
Thanks for the input!!! Anybody know how to warranty out a Weishi?? Prob start a seperate thread..... May have answer on HS within the hour!!
Thx!!!
JW
I pulled the balance.  Strangely enough, the coils were no longer touching.  Cleaned HS and re-oiled cock jewel. Did correct a small error between stud and curb pins.  Everything now looks great..... Although I don't trust the Weishi at this point.... Amp highest was 286.....trace looked good..... made minor timing adjustment,  and well see how she goes!!! Thanks to all for the input!!!
John W
John W
Sometimes there can be residue on the coils that can still make them stick under the right circumstances, like getting magnetized to the point they come in solid contact. Pulling the cock and balance gets the coils apart, and then if they gently touch it's not sufficient to get them to stick.
Also, sometimes things get magnetized to the point you have to demag components individually, in particular the balance/spring assembly. Wrap the balance with spring gently in tissue paper before demagnetizing off the cock; not doing so will almost definitely cause at least a tangled hairspring.
Hi all! I have managed to repair timegrapher.  It now shows an amazing beat error (like 7.5 ms).  I've centered just the banalnce in the pallet fork and the stud.position is WAY off.  I can see how this alone would pull the coils together.  Also at work I basically straddle a laser network printer (magnetic field anyone!!??).  Im about to correct beat error, probably clean HS in acetone.  Then demag.  and see what I have......  will.keep posted!!! Thanks for all the info, insight, and help.thus far!!!
JW
    • That was the intial reason I used mine the one time, timegrapher wouldn't pick up a signal, but it turned out to be something else. For fairly rare events like this, you're probably better off using Nicklesilver's method, or use an accurate pocket watch to match the oscillations up to. I think the tool is best suited to folk that time balances regularly, as would have been the case years ago. Maybe for small companies that let out their hairspring timing services, that didn't have the movement to work with. At the end of the day you already have the perfect timing device....the actual movement. The tool's convenience merely saves you the time and effort of unpinning and repinning the hairspring to the stud a few times to get it right.  Providing a " Prior Idiot " hasn't fitted incorrect train wheels 😄
    • If you restaff the balance correctly, there should be no need to repoise the wheel, unless it was messed with by a previous watchmaker. Here is an experiment to try that will explain my findings. Remove the balance from a correctly running watch that is marked "adjusted to 5 or 6 positions" or however many they claim. Place it on your poising tool, and you will find that it is out of poise. But, being out of poise, it has been adjusted for positional adjustments, to average the 5 or 10 seconds a day. It seems like you would want the wheel to be perfectly weighted all around, but it might run better a little heavier CU at the 4:30 position on the wheel. HERE is a good article that can explain it better than me. I also see a large amount of bad repairs, back when it was a cutthroat occupation. So if someone did re-poise a balance before you, you might have to do it again to correct it for positional accuracy. But at that point, its a sunken cost fallacy, as it will take a long time to make adjustments to 6 positional accuracy, so you might be better off finding an unmolested replacement.
    • This is a little clearer with the directions added. The spring must pull the click back not push. So the opposite way to which the click is being pulled into the teeth. As though its being opened out. Haha you've got it ! I didnt see the picture . Needs to come further around cw. Closer to the long leg.
