Bulova Case/Crystal reference needed
Hi, anyone have a source to match a Bulova crystal with a specific case number?  Looking for the Bulova-specific crystal part number (or GS if they made it).
Specifically a Bulova case Q526 (PO date code, 1980)
Thanks
Welcome to the forum.
Looks like a standard flat crystal so you just need to measure it.
Edit
Had a quick search and it's not clear which yours will be so can you post photos.
Also have you any experience of working on watches?
Edited by AndyGSi
Thanks Andy.
Yes, been restoring vintage watches for 15+ years.  I know how to measure/order a new crystal, and will do that as last resort.  But I know that there are still original Bulova crystals out there.  I just need to know the Bulova part number for it, based on my case number.  It's the reference material and documents that are scarce, finding the number is the hardest part in my experience.
Best,
15 hours ago, got2watch said:
Thanks Andy.
Best,
I believe Bulova's last case part catalog was the 1979 supplement. There may be a more recent one (seems like there should be) but I haven't seen it. Unfortunately, the highest 'Q' series case in that catalog is Q519. Some of the 'Q' series watches did take a crystal with the same numbers as the case, but not all of them.
Edited by GuyMontag
    • I’m fairly new to this and have worked on maybe 30 or so vintage and new movements. I recently went through a NH35 movement that I picked up with low amplitude. 140-150 degrees and impossible to regulate. I did find that the train bridge was not flat and when the screw nearest the barrel was tightened the wheels no longer spun freely so I replaced that with a spare and all good.  I cleaned it and lubricated it, including the balance cap jewels and it came right up at 220. I could get the beat error down below 0.5 but I’m chasing the rate all over. It will be down -15 and I’ll just touch the regulator arm and it will be up +15. This is a practice movement for me as I want to learn and improve making positional error corrections on the Etachron system.  The amplitude has fallen off a bit as well, 200. I’ll let it run overnight but is there anything I’m missing that can cause the rate to change so significantly with a very very small movement of the regulator? Could the hairspring be damaged and very particular to both the  regulator and stud position?  Could the regulator pin positions off? Either too open or closed?
    • The thing is you have to provide Longines with a serial number AND a reference number when you fill the form. I have the first one on the movement, but I can't see the other one, which sould look like L.xxxxxxxxxx. I mentionned the number inside the case and I sent the mail. Wait and see... Here are some picture I took yesterday when I received the watch.
    • The NAWCC has a watch repair forum. I haven't used it much myself,  but I have found the clock repair part of their forum to have friendly and helpful people. It might be a useful place for members to communicate if this forum is temporarily down. I would also recommend that each of  the moderators keep a list of all members email addresses,  to be held somewhere independent of this platform,  so that in the event of total disaster, it will be possible to notify members of any new arrangements. This site is a tremendous resource for horological education,  and a superb collection of practical knowledge from experienced watchmakers. Unfortunately forums like this can easily disappear overnight if the founder loses interest. I definitely agree that a backup plan would be a good idea.
    • Hi there Mathew, welcome to the forum.
