Hi, anyone have a source to match a Bulova crystal with a specific case number?  Looking for the Bulova-specific crystal part number (or GS if they made it).
Specifically a Bulova case Q526 (PO date code, 1980)
Thanks
Welcome to the forum.
Looks like a standard flat crystal so you just need to measure it.
Edit
Had a quick search and it's not clear which yours will be so can you post photos.
Also have you any experience of working on watches?
Edited by AndyGSi
Thanks Andy.
Yes, been restoring vintage watches for 15+ years.  I know how to measure/order a new crystal, and will do that as last resort.  But I know that there are still original Bulova crystals out there.  I just need to know the Bulova part number for it, based on my case number.  It's the reference material and documents that are scarce, finding the number is the hardest part in my experience.
Best,
15 hours ago, got2watch said:
Thanks Andy.
Best,
I believe Bulova's last case part catalog was the 1979 supplement. There may be a more recent one (seems like there should be) but I haven't seen it. Unfortunately, the highest 'Q' series case in that catalog is Q519. Some of the 'Q' series watches did take a crystal with the same numbers as the case, but not all of them.
Edited by GuyMontag
Ok, an update. I've attached some pics showing the dimensions of the crystal in question.  As you can see it's quite thick at 4.9mm.
I haven't found a decent match yet with GS catalog, I may end up having to grab a few that are close and apply trial/error at this point.
Any recommendations from some of you with a heavy vintage Bulova background would be appreciated.
p.s. The bezel is in good shape but would not turn at all.  Were these bezels fixed?  It did come off after soaking it a while, along with a rubber gasket inside, which makes me believe it is supposed to turn and is held in place by a thick o-ring (?).
Thanks.
These Bulova's will often have a tension ring with a step or cutout where the dial will fit, just in case you are going to try a 3rd party crystal, so be sure and check that. That dial looks somewhat similar to the 1979 Oceanographer '12503', but without the 'Day'. A lot of the '666' Bulova's were Oceanographers or Snorkels.
I've been keeping a database of pre-1980's Bulova crystals and it has two 30.2mm armored crystals; 1404AW (Oceanographer 'C' - link has a good photo of the crystal profile) - which I have a note saying that there is a GS crystal PA462-19D, and the 762AW. I think all three of those are currently on ebay, but if the tension ring is stepped it may be an issue. I've had mixed success swapping an existing stepped tension ring into a correct sized crystal that came with a flat tension ring.
Edited by GuyMontag
Looks like this is a good match but not sure about the curved edge.
