When I remove and vkesn the balance, especially vintage, the hairspring falls out from the regulator pins.  When I reinstall the balance I was getting poor numbers and when I looked the hairspring was outside and not between the pins.
I’m new to watch servicing and is there a technique for reinstalling the balance to insure the hairspring remains between the regulator pins?
The hairspring would usually be contained between the pins. Sometimes it's a pin and a boot that has a  lip that closes over the end of the pin . Sometimes it's a looped wire, othertimes an Etachron system.  What do you have ?
13 minutes ago, BobG said:
One was on a Bulova 10BC and the other a Hamilton vintage. Neither had a boot or wire.
It’s not as common for me on the Ettachron but it has happened.
Ah - the Bulova 10BC just has two vertical pins, no boot. I just finished a project with that movement too. This is what you will find on most movements from the 1940's and older. On larger pocket watch movements with stout hairsprings, as long as the spring is perfectly formed it will usually land directly between the pins when installed.
But on a small movement like the 10BC with a small regulator, the hairspring may land outside of the pins. It is easy to put in once the balance is mounted. Take your finest oiler (clean!) and just push down VERY gently on the hairspring right beside the regulator. As soon as the spring reaches the ends of the regulator pins it should jump in between them and land where expected. But you have to be really gentle with this or you will bend the spring out of flat. It is much more delicate on a small movement like yours. If the hairspring is not correctly formed, it may not jump in between the pins and if it does, it still may be incorrectly placed and not centered between them.
It is of course best to place the spring between the pins at the moment you are installing the stud into the balance cock, but that isn't always as easy as it sounds.
On movements with overcoil hairsprings there won't be a "boot", just the two pins. The Bulova 10BC has an overcoil, as I would imagine a vintage Hamilton would. Most of the time the spring stays in; if it doesn't it's simple enough to get back in place, just double check the spring is flat and centered.
I always rotate the regulator pins as far away from the stud as possible while installing the balance/hairspring.  That gives more flexibility to manipulate the hairspring without risking bending it.
Edited by LittleWatchShop
I did gently manipulate the spring back between the pins once installed but I thought there might be some technique either before or during the install to keep the spreng from falling out.
Onto an Etachron related question. When I install a new balance assembly onto the balance cock what is the best way to get back onto the movement?
I have tried placing the balance assembly onto the cock when it is lying on the bench, this method is easiest to get the spring in between the pins since I turn the regulator block to give me max opening but when I flip the cock over to install it the balance falls off. Last time I placed the balance assembly onto the movement and gently lowered the cock into place over it and the seated the spring and the stud.  What method do you use?
For small movements of any type and large ones where the stud has to fit into a hole of some sort, I stick the balance cock on its back to a steel bench block with a tiny bit of rodico, such that it overhangs the bench block. I Put the balance in such that I can lower the stud into its hole, and then because the cock overhangs the bench block I have access to tighten the stud screw underneath. Then remove the overhang and support the whole thing on its back if I have to close a regulator boot too.
For pocket watches that have an easier receptacle for the stud, like Waltham's wedge shaped indent that a screw tightens down over, or Hamilton's style where the stud slots in from the side, I put the balance in its jewel on the plate then lower the cock over it. The studs on those tend to jump right into position then for the screw to be tightened.
Your method works well if the stud had a screw but the Etachron is press fit and without the cock or bridge being supported I can’t press hard enough to seat it.  So my question is more about how to deal with replacing the balance assembly on the Etachron
I have never experienced this problem before. Even when the balance is allowed to hang freely on a balance stud, the hairspring should not free itself from the regulator pins.
Has your hairspring been damaged by excessive force and ended up getting coned?
Etacron studs can easily be mounted by pressing it in with the back of the tweezers. The balance cock can be placed upside down on the table or replaced back into movement to do this.
I think Alex Hamilton has a nice video on YouTube showing how it's done.
If you look at the Bulova 10BC movement there is nothing to keep the spring between the pins when the spring is extended.
Alex does have a video and he says to set the new balance assembly on the cock when it is upside down on the bench. Place the stud at the opening of the arm end locate the spring between the regulator pins. He the says pick the entire cock up and set it into the movement. Secure the cock and press fit the stud into place.
However when I do this and pick up the entire assembly by the cock the balance assembly  doesn’t stay connected.
I’ve also tried pressing in the stud while upside down on the bench but it takes a lot of force the I can’t easily get the butt if the tweezers under the balance wheel.
What do you do so that the balance assembly stays connected to the cock when the stud is not pressed in?
Edited by BobG
If you watch this video, the spring should stay within the regulator if the spring is not damaged. Even on really vintage movements where the regulator is just two brass pins, the hairspring never comes out of the regulator.
Are you sure your hairspring has not become coned? Could you post some photos.
If you are still worried that the hairspring will slip out, move the regulator arm as close to the stud carrier as possible.
Very important not to assume and always double check.
I like this the word never that's an absolute absolutely never except sometimes they do. It depends upon a whole variety of things. It really would be nice though if it never happened but unfortunately it does.
This by the way is really confusing I don't suppose we can get a picture? I may swipe a picture off the Internet and maybe you can explain help it with my confusion? Notice I put a little mark next to a screw? As I said your quote is really confusing normally when the balance bridge is upside down to place the entire balance wheel onto the bridge and get the stud to go back into its whole and you tighten the screw then the stud will  stay in place they could flip it over and put in the watch. So I don't understand it doesn't stay in place and why are you pushing so hard? We really do need pictures and a better description
Normally on a etachron  you would not remove the stud at least for cleaning it only be removing it if you're replacing the entire balance assembly? We really need pictures and better descriptions of exactly what you're trying to do and exactly how you're trying to assemble your balance system?
Regarding the Bulova 10BC, it's all back together and running. I gently reset the spring between the pins after I remounted the cock within the movement.
Regarding the Etachron, I am replacing the complete balance assembly.  I release the stud from the carrier arm and open the regulator pins when the cock is secure to the movement. I then remove the cock and balance and place the cock upside down on my bench. I lay the new balance assembly over it and align the stud  and insert the spring between the pins.
Now, when I pick up up the balance cock to place it back into the movement the balance assembly falls away because the stud is not secured.  What method do you use to get the new balance assembly back into the movement? It takes a bit of pressure to secure the stud into teh carrier arm and is not easily down on the bench when the cock is not secured.
OK, I watched Alex's video again and what he does when replacing the balance to the movement is pick up the complete balance assembly with the cock in his tweezers so the spring is not hanging down and  then place the entire cock and assembly into the movement. He is not trying to align the impact jewel at his point just the pivots so that he can secure the cock and press in the stud.
Interesting video he didn't get the history quite right and I learned something new
So what did I learn new well at about six minutes and 30 seconds I learned something interesting which I didn't realize you would normally ever have to do? Apparently you can use a razor blade to split the regulator pins the at the hairspring out and then of course you do have to remember to close it again. Which is quite fast dating because I don't actually think you're supposed to be doing this at all.
Some background: The Seiko NHxx movements are very common for modding or building custom watches. They are robust but mass produced. When modders receive them, being tinkerers that they are, they put it on their Timegrapher and try to regulate the timing. Sometimes they slip and other times the regulator pins and hairspring are not aligned very well and any adjustment causes the harispring to kink and then the watch is near imposible to regulate.
I few modders have sent me their NH35 movements that were "broken" assuming it was the keyless works jammed up but in 4 of the 5 I looked at it was the hairspring was bent, kinked or twisted. I could straighten them enough to get the movement going but the amplitude never came back. That's partially because I am not very good at hairspring work. So, I ordered a few complete balance assemblies (spring, wheel, staff) from AliX for $5.64.
This is why I am removing and installing new Etachron balance assemblies. I have not had a problem removing or re-inserting the hairspring into the regulator block between the regulator pins when the cock is out and  it is lying face up. I do need to use 7X magnification though. It is the reinserting the stud into the carrier that has caused me problems. It is tough when the cock is not mounted but getting it mounted when the stud is not secure was puzzling. Now I see I'm supposed to grab the balance with the cock as one piece so the spring can't fall out.
Ah, now I understand what you've been getting at; mounting the balance cock to the mainplate before the Etachron stud has been snapped into place and secured. 8:35 in the video for anyone else who has had trouble following what the challenge was here.
Thats a good way to bend a top balance pivot, lol...well it can be if you're not being careful. When I get noodle hairsprings, I support the balance with a piece of paper while carrying the cock, and help it into position.
Great.
👍👍  A+
Right
    • I often think about painting clear varnish on the coil.
    • I hate this battery release design in Ronda movements. It's an accident waiting to happen. One slip and the coil is gone. I wonder if it's a deliberate design.
    • so let's break this down the words restaffed balance wheel correctly would mean no distortion at all on the balance wheel. Which can be done but often isn't. Oftentimes balance wheels end up and times particularly discussing a bimetallic all bent up like the one in this discussion. If the balance wheel is out of round you definitely get a poise issue. You also get an issue if somebody pleases and out around balance wheel and then you fix the out of round now the wheel is poised incorrectly because somebody didn't physically make sure the balance wheel was correct in the first place. Yes people really do poise balance wheels that are neither flat or round it's quite annoying and then it typically with anything vintage there's an extreme likelihood of timing issues. Like the fun I had yesterday the wall thumb was 400 seconds fast and had a 202nd positional problem. So yes it's extremely common on vintage watches you're going to have things to fix from prior inappropriate repairs typically and it depends upon how it nitpicky you want to be here. In other words if you are statically poising the definition of poised would be if you give the balance wheel of push it will rotate eventually come to a stop and it will not rock back and forth at all is considered perfectly poised. Typically when I poise I don't worry about that I will let it rock back and forth because it still going to be within 15 seconds typically. Now the problem with statically poising absolutely perfectly is that it does not take into account the hairspring. This is why ideally if you are really obsessed you statically poise until your close and then finish with dynamic poising. This will take into account the hairspring collet that's probably not a poised collet. Yes Hamilton had another companies had poised collet's they hairspring itself affects the poise so for absolute perfect you have to dynamic poise. So the suggestion has been that it absolutely poised dynamically done balance wheel will not be statically poise absolutely perfectly.    this is an interesting one? In the United States of America over a time span and I don't remember the exact but it ended in the 60s there was a tear off on watches to protect the American watch industry. I've read the books on the tariffs specifications it would bump up the cost of better watches to making them expensive. This is why you will often see a nice Omega watch for instance that was regulated was adjusted and was still keeping really good time will be marked not adjusted. Because the quantity of jewels each jewel bumped up the cost adjustment adjustment and variety of positions bumped up the cost so a huge percentage of watches imported into this country will be not adjusted but they were adjusted at the factory it's just a terra thing then I suspect that even the cheapest of watches probably were somewhat adjusted because if they had zero adjustments I have no idea how bad the timekeeping would be? It's one of the problems of we don't actually have numbers of what the watches really should be doing we only have numbers of timekeeping basically when timing machines exist or for things like railroad grade watches where they absolutely had to know what the timekeeping is doing. So railroad timekeeping specification in this country is of watch Dependent up has to be within plus or -30/2 per week. Which if you compare it to the specifications of chronometer grade will ask which I think could be up to six seconds a day is better than a Rolex. this is one of my amusements at work. There we have that really nice which he timing machine full automatic microphone we look at every single watch and six positions and my boss once the watches all the keep really good time. So basically the watchmakers have learned to let the boss adjust the watches it seems to make him happy and we can do other things like service watches. So yesterday's fun on the 18 size Waltham to get the 400 timing down to think he got it down to 15 seconds it might've been better than that the Delta was still might've been within a minute much better than what it was before but still took more than an hour of time. When we don't specifically charge for this we charge for servicing of the watch we do not typically charge to make your watch keep time in multiple positions so yes it wastes a lot of time unless you're getting paid for it where it can definitely eat up a lot of time to fix vintage watches that I've had interesting repair histories. sorry I don't remember the brand name we once had a watch that was one of I take 1000 it actually was engraved number or something of something in other words it was a very expensive Swiss watch and I believe there was at least one shim under something. I always think of at the factory level if you have to place a shim to me it's a sign of poor manufacturing but there was a Swiss watch a nice watch that had it done. Of course what it may also be a sign of limited quantity of watches where things or adjusted at the factory we end up with interesting problems and I will pick on American pocket watches again with interesting repairs that can happen? For instance pocket watches dropped balance staff is broken possibly the whole jewels are broken and sometimes cap stones get broken. or worst-case I had a Hamilton 992 it actually had little notches taken out of the main plate I always wonder if it got hit by a train and things were dramatically bent in this watch somebody had ground the pallet fork bridge down to accommodate the balance wheel because the balance bridge had been bent to insane proportions it was bent so much it was no longer up and down in alignment so I always wondered if this particular watch got hit by a train. With its ultimate repair it would've been better to just replace the whole movement but instead we cannibalized another movements to replace all of the horribly mutilated parts. Now back to not watches hit by a train while somebody was crossing the railroad track. If the balance jewels are broken they are replaced but the same problem like we have on this group where do you get replacements? This means people in the field will get creative if they replace things with size differently than the original things will change. In other words the total length of the balance staff conceivably will change because they've changed the jewels and they're not properly sized. Then there's a problem of replacement balance staffs I personally have often theorized in the case of  bestfit  that they deliberately made the staffs oversize so the watchmaker can reduce the size. But what if you don't have a lay then what happens? A for instance the Hamilton 992B only has one balance staff as it's of friction staff but often times the friction staff doesn't fit because the replacement staff is slightly oversize which should be impossible but it happens. Often times I have to go through an assortment of staffs to find one that fits because I don't feel like reducing at the size to fit. More common though would be staffs with pivots that are too long and if the watchmaker does not have a lathe again how do they fix that problem well undesirable for us that have to deal with it down the road so an ideal perfect world the adjusted by the factory to whatever the specification was at the time and on a seven jewel American pocket watch it's not going to be railroad timekeeping. If we replace the staff in a proper fashion without bending or distorting anything the watch should keep time within the specification when it was originally made except of course we don't know what the specification was and they definitely did not have timing machines when this watch was made. If we replace the balanced staff with a factory original factory staff and everything should fit perfectly if the jewels were broken and we used factory jewels everything once again would be perfect. Although if you look in the parts book typically for American pocket watches for certain parts they recommend sending the entire watch or parts of the watch back because American watch manufacturing at least until the not sure exact date but sometime past the 20s definitely by the 50s watches were made in batches which is why everything has a serial number and the tools over the course of the batch tend to wear a little bit. So conceivably something made at the beginning and the end of the batch may not fit without adjustments. Plus of course there's variations in parts I like the pic on Elgin because they have one balance staff that comes in four different size variations and then a whole bunch of pivot variations all with the same part number so yes and an absolute perfect world which doesn't exist changing a balance staff with everything factory new would not require poising or truing the balance wheel because everything should still be perfect. But unfortunately in the 100+ year life of your watch things have happened. If you want to grasp that go back and start on page 1 of this discussion as the balance wheels in this discussion have had issues they're not flat the probably out of round there were issues with the jewels there is issues possibly with the staffs. Oh and yes apparently there's a donor watch and if the donor watch is not within a very close serial number range of the original watch it will have very likely sizing differences especially for anything related to the balance wheel because all the vintage watches were adjusted individually in the factory. If you look at a video on I can find it if you want to watch it on YouTube from I believe the 30s where you will see on escapement related stuff every single watch is adjusted which is why you can't just grab the balance wheel from one watch shove it into another one as they were adjusted at the factory
    • I see a lot of URLs pointing to 1drv.com which appears to be a CDN for OneDrive.
