Hi all of you,
I had an opportunity to buy a vintage watch early in the morning. It is supposed to be a Longines with a 25.17 movement. As there are some buyers who react very quickly when they see a new watch on that website, I had to make my mind at once. I made some researched immediately, and then I decided to get that watch. After that, I made some additional research, and I think it might be a real Longines.
Would you have the same opinion as you look at the pictures attached?
Does that mean it's a fake? I had a look on SERIAL-NUMBER-DECODER.CO.UK which confirms that the serial number 5472134 refers to 1936, but the website indicates that "I have estimated dates for years where I couldn't find any information so please consider this a guide only, it should be within a couple of years either way".
I had a try with another website which indicates 1937 and a third one which indicates 1936 (approximately).
May I still hope that it's a real Longines? If not ... I've been to quick in my decision🥴
It may just not be a 25.17 movement but I don't know enough about Longines to what came later.
Edit
Just found this which dates to 1935 so maybe the 25.17 was made before 1939 as stated on Ranfft.
https://www.joseph-watches.com/all-products/longines-cal-25-17-stainless-steel-1930s/
Re Edit
Done i little more searching and to me it looks like Ranfft is wrong
but can't find what actual date these were first produced.
Looking at other examples my thoughts would be it's a genuine movement but the dial
and case both look wrong so I suppose it all comes down to what you paid for it.
Edited by AndyGSi
Longines have a service where you can send the serial number and they will tell you the date and name of the agent the watch was sent to.
I'm not sure about the case, but I would expect "Longines" on the dial
Edited by mikepilk
I beleive Its a Longines, couple of variants to this calib were made,  one with flat and several  with overcoil H/S, overcoils were furthure modified, thus new designations.
 TG reveals it's  worth, when serviced.
Yep,  used it and they are pretty fast!
The thing is you have to provide Longines with a serial number AND a reference number when you fill the form. I have the first one on the movement, but I can't see the other one, which sould look like L.xxxxxxxxxx. I mentionned the number inside the case and I sent the mail. Wait and see...
Here are some picture I took yesterday when I received the watch.
The number in the case (1444) is the reference number. On older movements it's a shorter number.
When I applied I sent the serial number from the movement and the reference number on the case back. In my case for a 1967 Cal 30L the case number was 7855.
Thank you so much! So I think I provided the right information. I just have to wait now. I have disassembled / cleaned / reassembled the watch. Still alive 😀
The movement is a genuine Longines calibre 25.17, and is the version with the flat hairspring (no Breguet overcoil).
I’ll be very interested to see what Longines says about the case. It looks like a generic jobbers case and I think the movement was married with the case and dial after it left Longines.
Best Regards,
Mark
Did Longines contract ébauches to jewelers? Twas quite common to see branded movements sent out this way. Either way don’t assume nefariousness. Worst case you probably have an ‘unbranded’ watch with a Longines movement.
Oh, I see ... I'll just have to wait for the answer from Longines, and I will tell you.
When disassembling the watch, I noticed some figures on the back of the dial. I don't know whether they mean anything.
Thanks to all of you!
The format of the numbers on the case back are similar to Longines I have - a two digit and a four digit number.
The lack of "Longines" on the dial suggests this might be the case. But then you would expect the jeweller to put their name on.
We await the response from Longines.
Bad news: Longines doesn't provide this service free of charge any longer. I have to ask for an extract from the archives or a certificate of authenticity, but I'm afraid it's not worth the cost for this watch.
Too bad 🥴
  • Sad 1
Unfortunate…but you clearly have a Longines branded movement with a year 1936 serial consistent with the caliber. I checked the case maker of the last few Longines I worked on…
…same as your watch, so certainly you have grounds to honestly describe your watch as a Longines cal 25.17 tank with unbranded dial…and given the modesty of the watch IMO the Longines authentication wouldn’t dramatically alter the value, if that’s what you are hoping…as nucejoe suggests the value will mostly be determined by how well it runs…
Edited by rehajm
It works quite well. The only strange thing is that it loses 2/3 mn per day whereas the measurements indicate that it is fast by 1/2 mn. Maybe something wrong with the gear mechanism ...
How do the timegrapher readings look after the watch has been running for 24 hours?
Are you using a phone app or a dedicated timegrapher to take your measurements?
Best Regards,
Mark
I don't have a timegrapher. I have two ways to check the accuracy of my watches :
* First I have the app Watch Accuracy Meter
* Then I take a real measurement everyday at the same time, using timeis.com website
That double check works very well with my other watches (Seiko 5, Herma / Parrenin HP X40, Lov / AS 1710/11). Both the app and the real measurement indicate approximately the same thing (the app is a little optimistic). The Longines is the only one for which the app tells me it's fast whereas the real measurement every 24 hours indicates it's a little slow. That's why I guess the problem could come from another part than the balance wheel.
Apps like Watch Accuracy Meter can be inaccurate, and will read some watches better than others.
What daily rate does Watch Accuracy Meter give you if you check the Longines once it’s been running for 24 hours?
Best Regards,
Mark
19 minutes ago, mikepilk said:
A quick Google for Longines 25.17 found several similar watches - like this one with writing on the case back similar to yours
https://benjaminmarcello.nl/product/longines-cal-25-17-tank-from-1938/
Very interesting!
I answered the mail from Longines, explaining that I was a bit disappointed and that I wouldn't ask for a costly confirmation for a watch which isn't a high-end one ... and I received another email explaining that they couldn't not certify the authenticity of the watch, but they could specify that, according to the serial number on the caliber and to their handwritten records, the watch was produced in 1938. Great!
@Mercurial I will take the measurements and will keep you informed.
Thank you all. This forum is incredible 👍
    • My understanding is that In the Etachron system the spring is only centered n order to set the stud angle when the the pins are wide open and the regulator block in at the midway point.  After that the pins are rotated in one direction only so that the width between the spring and one of the studs is 1/2 width of the spring. This results in the spring always being closer to one stud than other one.
    • The idea is that the spring is centred between the pins when at rest. Then when the watch is running it will oscillate equally between the pins i.e. bounce off one pin then the other, as the hairspring breathes. If the spring is only hitting one pin, then it isn't centred, and most likely the pins are too far apart. Yes, the regulator pins are there to adjust the effective length of the hairspring. The spacing of the regulator pins should not affect the amplitude.  The vertical positions typically have lower amplitude than the horizontal ones. This has nothing to with the regulator - hairspring interaction. Increased friction in the verticals sucks energy from the system and reduces the amplitude. If the amplitude is less, the breathing is less. More tim between the pins = more effective length. Depending on how well the hairspring is centred, and which direction it sags, some vertical positions might run faster than the horizontal ones, and others slower. For example, if the spring is off centre towards on pin, and pressed against it by gravity, it might never bounce off that pin => faster. At the position 180 deg. away, the spring will spend more time in between the pins => slower.
    • Thank you all for the tips and insights. I'm looking carefully at the Sherline lathes with a milling attachment. I need to figure out exactly what I'd need to get in terms of the base lathe and attachments to be able to fabricate basic parts and learn how to fabricate some of the less basic ones- like a cannon pinion. Thank you again.
    • Welkom Sebastiaan! Veel plezier met deze hobby!
    • Welcome to the friendly forum.  Enjoy
