Who's doing what in the world of watches today.
Desperately in need of some human interaction please 😅 schools off for Easter and I haven't left my house for four days. I'm busy sorting and partially stripping back to identify old movements for donor parts, but warm and cosy in the Watchroom. I've managed about 50 up to now since Monday with only one unidentified ( which I might put up for Cluedo later ), so slowly filling up the new donor draw.  Strange that 25% of them are BFG movements. Probably another 100 or so to go through. The Flume book I'm using is easier to navigate than the Bestfit, this one dates to 1972 and is laid out better than the older editions, as far as I know there are more recent editions published.
Oh, I’m here for you mate 😀. You appreciate the military ones…for the last week I’ve been pecking away at rebuilding a functioning balance of an Omega 30T2 something something variant. The original balance had crowding issues and the hairspring is beat up and fragile. The staff isn’t fully seated and the spring has this bend I’m afraid to address…
…it’s like an overcoil bend right at the pins. I’ll try with the overcoil tweezers but not sure it can handle it. So, I’ve been rebuilding a new complete balance with bits from a couple donors. With a new staff and all the balance washers removed I’ve managed to get the replacement balance in beat and zeroed DU/DD. Going to attack the 70 second delta with the verticals today…
Hi N.E.W. You are starting the Hermit phase, soo have your food pushed under the door.  You have to come up for air   Cheers.
Hi. I have tried to upload a couple of images of containers bought from the RANGE in Aberdeen but I guess they are available at all RANGE stores.  They are plastic coxes withe hinged lids containing screw topped containers total 24  usefull for small parts or movements. I got one to try and will Ger some more.  Retail at about. £ 2.50
  • Haha 2
Starting from scratch with no washers is probably the best plan 👍
4 hours ago, AndyGSi said:
Just going through a lot of quartz that look like they've been robbed
from their cases for the gold so hoping most are working.
Ha, that was my initiation to watch repair, sorting through a bucketful of quartz movements, I loved it.
Oh wow, they're great, I have a Range store just up the road from me. Guess where I'm going tomorrow.
15 minutes ago, MariusJacob said:
I must admit I am full of envy.
My wife forced me to go on holidays for a week, so now I am in the cold nowhere, far from my workbench, and all I can do is drink beers and read this forum.
Thanks for giving me some joy with your posts, otherwise I would be very bored.
You have a wife, you should not be bored 😉
One can never be bored drinking beer and reading the forum.
Replacing a battery for my mother in law, with my ever expanding collection of batteries, did I have the correct one? I'll let you guess.
I hope it's not alkaline....🤔...mother in-law...🤔.....yes alkaline will be just fine.
  • Haha 3
So being a ladies were you luck with an SR621 or unlucky with an SR5XX?
I really don't remember what you are talking about.
16 minutes ago, RichardHarris123 said:
I don't own a quartz watch, nor do I usually work on them but friends and family have asked for batteries replacing.
Still learning.
I do own a quartz watch, I could change the battery myself, but I take it to the watchmaker of my neighbourhood so I can talk face to face with somebody about watches.
42 minutes ago, Neverenoughwatches said:
Lol ok, well I'm not about to explain it, I'm a bit fuzzy on it myself, I'll get it all arse about face.....actually that might be part of it, now I come to think about it.
I must update myself, I guess nowadays the lubrication procedures and assembly protocols have improved or, at least, changed.
I hope there is still hope for vintage tools in this area.
I made a brass object sort of approximating the shape of a balance staff on my lathe (obvs learning), cleaned and reassembled a Timex M24 from a late 60's watch the seller said "needs new battery" and installed a NOS Elgin mainspring that showed up in the mail into an 1890s 6 size that had been waiting on the bench. To find it runs ++++ on the timegrapher, at a wicked 100° amplitude.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
