Hello,
I have recently bought this watchmakers lathe and wanted to identify it's manufacturer. Since there is no maker's mark anywhere on the machine I started googling and found out that this thing is actually pretty odd in the way it was built.
Firstly the (presumably) hardened bed surfaces seem to have been screwed to the base and the screw heads ground over. I didn't find any similar lathe where this was done.
Second thing that I didn't find anywhere else is that there is no slot cut all the way through the bed so the normal method of attaching steady rests or cross slides to the bed with a bolt from the bottom isn't possible. Here it is done like in most head- and tail stocks with an eccentric clamping mechanism from the top to clamp both to the bed and the cross slide. Again something I haven't found else where.
Because of the color of the tarnished paint and overall style of the machine I believe it may be of american origin.
Another piece of potentially important information is, that I have another head stock of a more modern Boley and it fits the bed perfectly.
If you have ever seen something like this before or could give me any information at all I would be very gracious. And of course if you have any more questions I would be glad to answer them. Thanks
Greetings from Germany
yes I would say this is definitely unusual I don't think I've ever seen this either. But their are quite a few people manufacturing lathes for watchmakers and instrumentation and toolroom use that all can look similar. In addition to stuff that was made for factories. With often times will find pictures of factory tools with no identifications no marking and no idea what exactly they were designed for
then this part of the lathe looks quite interesting any idea why it's been designed this way?
Yeah I thought so too. It seems to be original since the paint is the same. My theory is, that it is either some sort of an attachment point for an indexing assembly or for a collet closer like this one.
Edited by oenkyi
image blocking text
23 minutes ago, caseback said:
Any other markings than the "256"?Screenshot_20250417_192550_Chrome.thumb.jpg.450c1582eb0d2100c2e4056aed40ec5f.jpg
Yeah there are some numbers punched into some of the parts. Namely the base of the tail stock:
the mounting block between bed and cross slide:
signal-2025-04-17-194851_002.thumb.jpeg.f5780fd70c29317becd1da3e2855a786.jpegsignal-2025-04-17-194851_003.thumb.jpeg.d6290e13596d1536c093756970c601ac.jpeg
the head stock:
and some components of the cross slide assembly:
signal-2025-04-17-194851_005.thumb.jpeg.a9c42b429af7898c7c10fc19020567d4.jpegsignal-2025-04-17-194851_006.thumb.jpeg.15fff0613db4fd3cf573b7939c583274.jpeg
The different numbers are a clue to the lathe being a collection of parts although saying that some manufacturers said that any parts they made would all fit each other part within tolerance
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
