On 4/17/2025 at 12:46 PM, SwissSeiko said:
As I recall, you have a sherline lathe, so that should be a pretty easy thing for you to make!
It would be fine to try. Maybe start with a larger bezel and cut it down.
My friend says he wants me to proceed with making a bezel. He is not expecting rolex identical. Just a solution that will hold the crystal.
So, now my request for help has changed.
Any guidance on making the bezel would be helpful. I can only guess at the profile.
Material??
Material??
I'd start with stainless steel tube.
Yes indeed. I have thought about starting with a washer, but that would be unknown metal. @nickelsilver has suggested 316L on another forum. I am going to see what form I can buy...hopefully tubular as you suggest.
