Hi it’s probably a snap back. I have found Tissot backs very tight and need a case back tool to clamp the movement and pry the back off. Conversely you will naad the case back press to get it back on again.  Both on eBay or Ali Express.
11 minutes ago, bosstaki said:
The case back is perfectly aligned to the case and has no provisions for a screwing tool. The T-Sport series has snap on backs.
Edited by Kalanag
The ones I have opened also do not have a pry point , hence the reason for the tool. The watch is clamped in the tool and a blade is screwed into the seam, the blade being chamfered lifts the back then the screw shaft is turned and the back comes off have a look on Ali express for case back removal tools
