Cap jewel with what looks like a circular engraving around the edge
There's a couple of 5420 balance complete on eBay but they aren't cheap. https://www.ebay.co.uk/itm/388266390588
one original showed up on my UK Ebay feed this morning...
By LittleWatchShop · Posted
Try to get one with the centering pin. They are often missing. -
Exactly, that's why I wanted to ask.
You're right. My first measurement was done using a guessometer (calipers). My 88,8mm diameter faceplate just clears a 5,6mm stack of gauge blocks. So: exacly 100mm. The relieved center might indeed give you a bit extra. But, stepping a bit: It wouldn't make sense for a faceplate manufacturer to make a faceplate that wouldn't fit most 8mm lathes. So 4" is not very likely.
