I decided to change the design of the site. The main reason was that I was tired of the huge banner at the top which was always there.
I hope you guys don't mind, however, if you prefer the old design you can change back as long as you are logged in. You will see a link at the bottom of the page "Change Theme" and I have made "Old Theme" available there.
:thumbsu:
I don't have a lot to say on the forums, but check in everyday & this design is far better. Looks better quality too.
  • 10 months later...
A new version of the software is coming out soon. That will be fun. Or maybe not.
Excellent, the site is working great from here, never a glitch. I'm excited to see the new changes and hope the new version doesn't involve too much for you Mark.
While this topic is active, I might as well put in a suggestion: the .crosshatch CSS style of the current theme adds a lot to the rendering time and makes Safari on my Mac stutter when scrolling pages. If I remove the crosshatch (via the web inspector) scrolling speed becomes normal again.
{    /* background: url('/Images/crosshatch.png'); */
    background-repeat: repeat;
    background-attachment: fixed;
It's probably only noticeable on slower computers / graphics cards. I see it on my old MacBook Pro with OS X 10.8 and ATI Radeon X1600 graphics but not on my OS X 10.10 machine.
Thanks Rob - I never noticed that on my computer but if it is causing problems I will remove it.
:thumbsu:  Although, I didn't notice lag. I think its better without it. Cleaner. :geek:
Hi everybody.
Mark, I have a problem and I don't know if it is common to others, related with this migration, or not for all. Even I logoff my seccion, when I came again to the WRT site, I was logged on. It's happened for me for the last several logoffs.
It is normal?
Thanks
Clear your cookies, I have a website & migrated to the same software as here & some members where reporting having issues with being logged off between visits or having trouble logging on in the first place. once they cleared the sites cookie & got a fresh one everything was OK.
Hi again. I made this but still the same . :pulling-hair-out:  I really don't know what I must do to fix this (assuming that this problem is in my PC). Yesterday night I left the site with "Sign Out", but today morning I'm back already "Signed In". I don't have problem with this but if it is a problem of the site, I suppose it will better to investigate what is wrong. Any other suggestion?
I remember to did no check any box, and only was show the box asking me if I want to remember my password. I never do this for all softwares or sites. Now, I can't see any box to check as when I open the site I am already login.
Cheers too
Ricardo
Edited by RicardoG
The box is checked by default so you will need to click on the box to remove the check mark. Since it doesn't show now, I will assume you will need to clear the saved passwords, cookies, history, etc in the tools menu if using explorer. Then re open the page and log in, taking care of removing the default check mark and accepting cookies afterwards since the page requires it.
Hope it helps,
Bob
I again. I did try to do all again. Clear all my cookies and clear all my temporary internen files and historic (now every site that I go with password to login, ask me to remember or not...), I saw the checked box you told and uncheck again, and even all of this, still the same. I am not worry due I am only one that use my PC, and I bring this to here only because I thought could be a problem of the site or of the server. I can live with this and save me time to make logon . :D Anyway, my sincere thanks for the help. I appreciate.
Ricardo
Edited by RicardoG
I wonder if it could be a matter of your os needing the latest updates. What is your operating system and what browser?
Thanks in advance.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
