Hi
I have a slot in a block. I didn't think Etachron had slots with a keeper like some Swiss systems.
Do you have regulating pins, or a slot as per a normal Etachron? Post some photos.
By LittleWatchShop · Posted
I will post some pictures later -
Yes, I understand that in te Etachron system the regulator block is turned anti-clockwise. If I look at the spring in relation to the pins as I turn the block the gap appear to be "closing" and the spring is now closer to one pin than the other. Closing is not the correct term because the pin gap is always contant but in relation to the spring the gap appears to get smaller and smaller until the spring is actually on the pin.
I have one of these (different colour scheme) very happy with it! Not so happy with the recent results... but that is nothing to do with the tester. My wife wanted a waterproof watch she could take on holiday so I fixed up a nice Mickey Mouse Seiko 5 for her. But after getting a non runner working nicely it failed the pressure test with water seeping in around the crystal 😞
