Seiko 6139 Repair And "restoration"
OK, looks like the only reasonable option left is to shorten the hairspring a little. Is it pinned to the stud or it is glued? -
As I understand it, but please let me know if I'm wrong, the two reversing wheels should be treated with Fixodrop and then only the side of the arbor should be oiled. Correct? Great tip! I'll use my automatic oiler for this or even better my Horotec oil pusher. Yes, it sounds dramatic and Mark warns about it in his series of videos where he does a complete service of the 3135 calibre. By the way, have you looked through Mark's videos for this calibre? Do you have any comments or additions, or can I follow the series with a clear conscience? When he removes these parts, he starts with the jewel. Shouldn't it be easier or safer to first remove the cam yoke that the jewel sits on, then remove the jewel from the cam yoke, and finally remove the spring? I'll be honest, I don't really understand the risk. Can you elaborate? Maybe this part is very thin and fragile?
Yey i win , they dont call me Tommy the tool tinkerer for nofin, I'll pm my address, how soon can i expect it to arrive ? 🙂 Haha, just realised my mistake 🤦♂️ Think Rich think before you press submit reply 😖 -
Thanks. I tried this. There is a point when B bumps up against the bottom of A. If I continue to force B, it then tries to go under A risking A being pushed off the balance. In short, there appears to be a limit to how much swing B can achieve and best of my ability I’ve hit this limit. Lookd fine when I checked it, but I’ll put it under the scope again to be sure. Thanks
Hi Murks, You can get one of the screws from one side and put it on the other. You say the balance doesn't even move on the poising tool, are the pivots OK?
