Welcome to the forum. This is an old thread and the original poster hasn't been on for 12 months.
In my experience you'll only find a Bulova Part No. if it's a special crystal.
Hello, I’m interested as well, mine as for the crown bumpers and well as the other side has broken or chipped, I would like to know if you also do the other side as well? If you do would you be able to print them on red for me? Thanks
Syringes as pusher tools or as replacement pins? I took a first try at fitting a new pin. I have a huge bag of tiny brass wire segments I use for heat bluing. They are flat or rectangular so I tried stoning them closer to a round taper with a pin vise and India stone. The taper is a little too pointy and severe so will probably redo this but I am pleased with myself for repairing a 135 year old part.
thanks for the reply, I got it working, I was just trying to remove the stem inside the keyless works by partially disassembling the movement to get there, but since I was not able to move the hands to the 12 o'clock before removing them I was wondering what was the right procedure on a GTM, but I got it, just removed them as they were and at the time of installing them just move them until date changes and installed them at the 12o'clock and it worked perfect, I though it was a bit different with the GMT hand.
