A family member dropped off this Suter watch today and asked if I could get it working. I quickly removed the case back and it started working right away. I put the back on and flipped it over and it stopped.....? After playing with it for a few I thought that there was pressure from the back pushing on and stopping the movement but then I noticed that with the back off it stops when turned right side up or as you would wear it. What could be going on here? I am attaching some pics. The movement says. SU641
I also noticed the crystal is badly scratched and would like to replace it. It measures 15mm OD. It is also missing its gasket measuring 18mm. Those may be easy to find but I haven't looked yet. Just want to make sure I can get it to run first. post-56-0-87925400-1396564338_thumb.jpgpost-56-0-88439400-1396564355_thumb.jpgpost-56-0-09186100-1396564389_thumb.jpg
At first glance, the jewel on the incabloc that is visible, appears to not be locked in properly. This could result in the jewel sitting off slightly in its setting and causing the problem that you described. Before going any further pop the locking clip (left hand side as looking at the photograph) in properly and see if that cures the problem. This may just have been an optical illusion due to the angle at which the photograph has been taken. As it is an old watch, it possibly requires a strip down and clean anyway.
Regarding the crystal if you cannot source a new one, you could carefully polish out the scratches and re- finish it. I do this a lot when refurbishing watches, it is time consuming, but excellent results can be achieved.
Edited by Geo
I've had this problem on a couple of watches - stopping in one position and running fine in the other - and both times it turned out to be a jewel problem.
Edited by WillFly
As Geo stated, the incabloc spring is not located. This will cause the incabloc to be off kilter.
I could be wrong but that glass looks like a mineral glass. Tap it gently with your tweezers, does it sound like glass or perspex?
    • The ones I have opened also do not have a pry point , hence the reason for the tool. The watch is clamped in the tool and a blade is screwed into the seam, the blade being chamfered lifts the back then the screw shaft is turned and the back comes off have a look on Ali express for case back removal tools
    • I don't think I need to know more about the Orient watch question, so please don't write anything related to the topic, but if you know where I can buy the watch's jewels = rubies and gems shock protection, I would like to know.
    • It's an exhibition back so no access as you suggest.
    • I have no experience with this watch, but looking at the pictures from the ebay listing linked above, it looks like the outer metal bezel at the back of the watch may not be part of the case proper.  It looks like the watch and strap are sandwiched together, and an inner case may push out of the rear bezel towards the front of the watch.  A case style similar to the Roamer watches where the crystal, movement and caseback pushed out through the back of an outer bezel, only in reverse - this one may push out towards the front.  To test this, you would need to hold the watch, dial down, supporting the dial side of the watch around the edge of the bezel without touching the bezel itself. Then push down carefully on the inner metal ring you can see at the back of the watch. I’m speculating here, proceed at your own risk. Hopefully someone with hands on experience of these watches can chime in! Best Regards, Mark
    • Thanks, Mark. That's the kind of reassurance many of us wanted to hear! Yes, life is unfortunately unpredictable, and it would be a shame if the many dedicated WRT: ers became stranded if, god forbid, something happened to you and WRT stopped working.
