I have a number of old watches and, while the dial, movement and outer casings are generally in reasonably clean condition, the one area which often looks green or dirty is the inner rim of the case. Any recommendations on cleaning this area up without affecting the movement?
I agree - removing the movement is of paramount importance before cleaning the inside of a case as any debris can easily drift into the train.
If you can master removing the watch movement from the case then you open up opportunities like being able to use an ultrasonic cleaner.
Just make sure the case is bone dry before re-assembly :)
  • 8 months later...
hmm...!.. why I receive a mail for this topic dating from a year or so?? there is no new message ,, I don't understand.
Sorry - i think this might be my fault. Notice the forum cron job had stopped working so I kicked it back into shape earlier today.
oh okay it works fine now as I receive the messages ...The watches are one of my passions. In fact, i'm in the old and antique TVs more than a year but I still collect the watches.  ;)
    • The ones I have opened also do not have a pry point , hence the reason for the tool. The watch is clamped in the tool and a blade is screwed into the seam, the blade being chamfered lifts the back then the screw shaft is turned and the back comes off have a look on Ali express for case back removal tools
    • I don't think I need to know more about the question now, so please don't write anything related to the topic. Thank you to everyone who wrote. Have a nice day.
    • It's an exhibition back so no access as you suggest.
    • I have no experience with this watch, but looking at the pictures from the ebay listing linked above, it looks like the outer metal bezel at the back of the watch may not be part of the case proper.  It looks like the watch and strap are sandwiched together, and an inner case may push out of the rear bezel towards the front of the watch.  A case style similar to the Roamer watches where the crystal, movement and caseback pushed out through the back of an outer bezel, only in reverse - this one may push out towards the front.  To test this, you would need to hold the watch, dial down, supporting the dial side of the watch around the edge of the bezel without touching the bezel itself. Then push down carefully on the inner metal ring you can see at the back of the watch. I’m speculating here, proceed at your own risk. Hopefully someone with hands on experience of these watches can chime in! Best Regards, Mark
    • Thanks, Mark. That's the kind of reassurance many of us wanted to hear! Yes, life is unfortunately unpredictable, and it would be a shame if the many dedicated WRT: ers became stranded if, god forbid, something happened to you and WRT stopped working.
