Carriage Clock Cleaning Disaster
Scouseget
I have had a lovely carriage clock for many years and, of course, it has received zero maintenance in all that time - no lubrication, and certainly no strip-down and cleaning. It's a T.S Elliott clock, with a French 7 jewel unadjusted (whatever that means) movement. It has an escapement on a separate little plate that comes off cleanly by removing a few screws.
Having recently  become a member of the WRT community, I decided overhaul it and subsequently stripped it down completely without any problems at all. Then came the cleaning. I read up on this, and other forums and websites to find out what type of cleaning solution I should get for my recently acquired ultrasonic cleaner. I settled on a multi-purpose degreaser, which I was assured would work fine providing the brass work wasn't lacquered. I checked the main plate and satisfied myself that it was un-lacquered, then diluted the degreaser (sodium hydroxide, sodium metasilicate, and 2-butoxyethanol) to about 1 part to 8 parts warm water and proceeded to clean all the parts.
All the gear wheels came out completely tarnished, as in black, or more accurately gun metal blue, almost iridescent. The mainspring barrel came out less coloured but nonetheless still very discoloured. And worst of all, all the "brass" pieces, with the exception of the two plates, one of which was the one I initially checked, came out with the brass colour pretty well completely removed.
I now realize that the only pieces that were actually brass were the main plates, everything else on the case was some type of base metal (plated aluminium perhaps). The gears I assume are some type of alloy. So I now have a pretty uniquely coloured carriage clock, and there's probably nothing I can do to remedy that and I'll complete the overhaul and hope that my wife doesn't actually notice the not so subtle change in colour.
I do have one question, and that is, given my traumatic experience, how should I clean and lube the jewelled escapement, as seen in the attached photo?
Also, any thoughts on my choice of cleaning solution?
Thanks, as always, for your collective wisdom.
Roger
post-1720-0-18850900-1453594191_thumb.jp
When it comes to cleaning these clocks I always used Brasso and a soft polishing brush and an old piece of cloth. All brass parts would be polished with the brasso then washed out in petrol, dried in sawdust and then chalked. The platform all the brass cleaned with brasso and washed in the same way, then dried, all the parts would be put into a watch cleaning basket and put through the cleaner. All the screws would be polished with small needle files buffed with different emery sticks until highly polished and then blued. The only screw not blued is the one that is adjusted for the depth to the contrite wheel. The reason I used French chalk is it stops tarnish, it is a very old method. The cleaning and polishing would be the same for the case, then finished by lacquering.
I forgot to mention all the screws are cleaned in the cleaning machine. The arbor for winding is also cleaned up, any burr is taken of and buffed with emery sticks, this goes for the click and click spring and hand set.
I think I've covered it all.
You should be able to buy a block of French chalk and what is called a chalk brush. You brush the chalk across the brush then brush the brass part, you do not need to brush the part hard, just a little light brush is all that's needed. I would then use my blower and blow away any access. It must be French chalk, no other will do.
Don't forget if bushing is undertaken it should be invisible to the naked eye, with the oil well you shouldn't be able to see that a bush is in place, so these ready made bushings are not good enough you should always make your own on a lathe. Back to bluing screws, I used an old copper penny over a spirit lamp, when the right shade of blue is obtained drop the screw in oil I used 3 in one, this adds a nice shine to the screws then clean in a cleaning machine. I had an old machine just for this type of work.
All that I've posted above about polishing and cleaning carriage clocks is the way all French Clocks should be undertaken with one exception if the movement isn't visible you can re-bush in the normal way, but make sure it is tidy and correct and the pinion has the correct depth to operate in.
Always remove the springs with a good mainspring winder.
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
