good job,guy! it is unimaginable. the watch was pretty old,but you renew it .
thank you for sharing the repairing process and the material. nice post
  • 2 years later...
Excellent stuff. I have a 4205-0155 on the way. I intend to replace the crystal. Is there a gasket for the crystal in this case? If so, any clues as to a part number?
Perhaps it's a 86590030
Hi
To be honest I never changed a crystal in any of mine. I found it was so easy to break the crystal retaining ring, that’s if it’s not already broken, that I mostly polished up the original crystal in situ.  It take a long time but can be done. I remember one that I did was in such a bad state I replaced it with a domed acrylic one and it looked quite good. Obviously it’s not going to be waterproof but I just wore mine for casual wear.
Good luck with the watch!
  • 3 years later...
On 2/1/2016 at 9:12 PM, Davey57 said:
Flipping it over and the three train bridge retaining screws are removed. One of them holds a small friction spring in contact with the centre seconds pinion, meant to show that sorry.
Lift the bridge clear but watch out for the transmission wheel pinion that is left behind. It can stick to the underside of the bridge and drop out when you aren’t looking, the small intermediate wheel next to it in the black box is also free to fall off. I am beginning to think that instead of removing the left handed screw and removing the transmission wheel you could leave it attached and then there would be no danger of losing the pinion below it. Removing the pawl lever as described above would still allow the mainspring to be wound down. In 4205B movements this is one unit anyway so not to worry.
Barrel,train wheels and the centre seconds pinion are next. Then the pallet bridge and fork.
At the beginning I mentioned that sometimes the winding mechanism might not feel right, you might get a few turns of the crown and then it goes loose then winds again.
Given the age of these things by now there must be considerable wear and some of the gears in the winding mechanism are well worn
I found that the winding pinion on the stem was not contacting the sliding crown on the winding bridge very well, it was tending to lie to one side and flop about. So what I did was to bend the spring that you can see inside the black box so that it puts more tension on the sliding crown and it seemed to keep things engaged a bit more positively. It’s easier to do this once spring has been removed.
Take off the winding bridge and it’s almost there.
Remove the centre wheel bridge and take out the escape wheel.
Pull off the cannon pinion and remove the centre wheel.
The barrel and spring.
And the spring is removed.
All the parts ready for cleaning.
And that's it. Once everything is cleaned and ready, reassembly is just the reverse procedure.
I will be quite happy to post the pictures of it going back together if you wish.
Either way I hope it has been of help and that I have made things easy to understand.
It’s difficult to know exactly how much detail to include or omit. If anything is unclear or just plain wrong please let me know and I will try to explain things or make some edits to the post.
Hello, great walk through. I am at the moment stripping down this movement. 4205-0155... As when I lifted the oscillating weight plate up the Pawl Lever dropped on the floor! But I'm now a little unsure how it goes back? Obviously the small post under the bearing slots in to the jewel, but does it then just butt up against the end of the Sweep second hand friction spring which sits just under the Pawl lever covering the centre hole. I'm a little stumped over that little assembly!!!! Any help would b greatly appreciated.
 This is also my first Automatic movement! I'm not completely green as I've done other movements but never Auto...
 Many thanks,
              David...
Hello, excellent walk through... But I need a little help!!!
 At the moment I've got the same 4205-0155 movement stripped down but I'm struggling to get the lid off the mainspring barrel!!!! Is there something unusual that I need to do. I've tried putting it on hard surface & pushing down gently on the teeth but nothing! There is no recess to put a tool to gently lever it off! Any help would be appreciated. It's such a small and dainty barrel that I'm scared to push too hard!
 Hopefully hear something soon.
Many thanks....
Many thanks....
They’re not really meant to be taken apart so Seiko doesn’t make it easy to do so. But you can with patience and a scalpel, by gently pushing it along the very thin line where the top and bottom meet and separating it that way. It takes patience though. I’ll just quote a video of mine; it’s around the half way mark:
https://youtu.be/yrhYjLaoQvM
I use my nails to open it. It takes me a little bit more than Mark, but I can open the barrels in one minute or two.
    • @VWatchie I think under the current climate you're better keeping whatever the Patron fee is for you and your family. As for me, I think I've seen enough.
    • Did you just swear at me matey?? I’m sorry, I’m not divulging personal information but there’s always personal reasons. There’s not much more than I can do other than plod along as best I can. However, my health is good now and I’m regularly getting plenty of exercise to keep it that way 👍 You know what. The ads don’t even cover a small percentage of what it costs to serve this site. I find most of it personally. If there are complaints then so be it. I do my best.  in fact - I have zero issues turning them off. Would that make the complainers happy?
    • Same question that was asked last time Hakan, and emphasis was placed on it. It was ignored. The thread should still be there, if not I have a copy of his reply.
    • This is probably the single most important point. One of my best friends, 48 years old at the time, suffered a massive stroke about 15 years ago. He barely survived, but his life was never the same after that. If you had asked me back then to guess which of my friends might have a stroke and nearly die, he would have been the very last one I'd have picked. He was perfectly healthy, played tennis three times a week, ran a successful business, was full of life, and had a wonderful wife and well-behaved teenage kids. The harsh truth is, we never know when it’s "game over." @Mark, I truly wish you a long, happy, and successful life. But have you given any thought to some kind of backup plan for WRT in case the worst should happen? Is there anyone who could keep the site going? If you can reassure us in some way, it would mean more than a lot to us!
