don't know if I will try the class or not . I didn't see a schedule of when the classes are taking place. so I am not sure if it would fit my work time or not .
No Daniel, there is no schedule, you take them when you can and as long as you can. Just visit the free sample lesson and you will understand what I mean. If you are spending that kind of money in tools and what not, might as well get the class I think. It is still a very personal decision though and I'm not associated to them in any way but I have learned a lot from them.
I've cleaned quite balances ultrasonically over the years without any problem. If in doubt, try it on an old movement first to see how you get on. The only thing I will not ultrasonically clean I'd the dial. I tried it early on and it destroyed the finish.
Edited by Geo
Mark re-attaches the balance to the plate prior to cleaning in his videos, and the manually cleans the jewels after. Whipping around a liquid bath seems more violent and sitting stationary in an ultrasonic cleaner so I'd assume it's safe.
Mmmmmmm, sloshing about may be Ok, I'm concerned that 22Mhz may mess with the hair spring..............
What about the Pallets?
I clean them all the time ultrasonically and have never had a problem. Edited by Geo
I have been collecting the tiny little Wilkin and Sons jam jars you get in some cafés, I can fit 3 in my ultrasonic cleaner and it means I can have a different fluid in each one if I wish.
The brass fine mesh balls are useful sometimes as well for the really small bits.
Like Bob and George I clean just about everything bar the dial and pointers.  The only thing I would say is dont use any solvent cleaner type substance that could dissolve the shellac/glue holding the jewels in place.
Since seeing Mark do it, I have started putting the balance back on the plate and it seems to be perfectly ok that way, it does not take long plus the plate gets a clean as well.
Cheers,
Vic
I have been using Mark,s method with my L&R cleaning machine (that also ultrasonic cleans in all three jars) and perfect results every time.
Pallets could be a problem if one of them is loose other than this scenario no problems.
As title really, all of the sites I normally use for my watchmaking, Cousinsuk, HSWalsh, and Gleave & Co, are all based in the UK, and all cannot ship the products I need to Finland due to being dangerous chemicals.
I am preparing my Elma Super Elite, watch parts cleaner machine, and need these following products...
L&R 111 Cleaning Solution
L&R #3 Rinsing Solution
15508778617_5ff71f4ba5.jpg2014-11-02_2210 by Micky.!, on Flickr
So as you can see, I am a little stuck on where to buy the above products from, and I don't know of anywhere in Finland that would possible sell them :(
Edited by SSTEEL
Hi Micky,
Have you tried some US suppliers? Is it the same situation as with UK?
This is unbelievable but I searched for "watchmakers supplies, Finland" and I got "Rio Grande" suppliers... not even supplying watch related products. Apparently Mexico has borders with your country!! :D
In any case, if you don't find one close to home, check our directory of suppliers, maybe there is one close enough that can send what you need, probably ground shipping. I believe it is going to be expensive at best. If you were to find one in Finland, tell Mark so he can add it to our directory.
Bob
Not cheap by any means, but no other option, so just purchased the L&R #3 and #111.  Both are the 3.8 litre bottles.
#3 €55.00
#111 €59
Shipping €20
Total €134
Edited by SSTEEL
Ouch, that is a bit pricey.
As this is a hobby with me I'm going to experiment with brewing my own. I picked up an old watch cleaning machine recently and l love to experiment. I will post how I get on whether good or bad.
I clean all my balances in the ultrasonic and have had no problems, however I have learnt to be a bit more careful with the Pallets as the cleaning solution can get a bit warm if used for an extended time period ( I personally can use it quite a lot in a one session) and sometimes Pallet jewels can come loose due to the shellac/ adhesive softening because of the increase in temperature within the cleaning solution...
Cleaned a watch this afternoon using my L&R machine and noticed the parts are a little bit sticky.  Thought it was my tweezes but i think the movement parts have a film of some sort on them. I have recently cleaned several clock parts in the L&R & wondering if there was just too much old oil etc & it has contaminated my cleaning solution.
I have been keeping count using two counts for clock movements & it totals 18 washes. Any suggestions guys.
I have been using Elma
I would not normally do clocks but if I did then I would use a separate jar of cleaner for the clock parts.
I used to work in a place where the clockies would take our used watch fluid to clean their watch parts (too dirty for us but clean enough for them). The exception was platform escapements which would not normally be a problem in the watch jar.
I have never used the Elma fluid but I have almost run out of my current stuff and was thinking of giving the Elma fluid a try. Apparently you use distilled water in the first rinse. Right now I use L&R watch rinse in the second and third jars. When the second jar gets dirty I will swap the third jar in it's place, discard the second jar's fluid and refresh it with new fluid - it becomes my new final rinse. Less waste this way.
    • Did you watch the whole video? Once Alex has set the stud, he first corrects the best error, then checks that the hairspring coils are breathing concentrically, then turns the stud to centre the hairspring between the open regulator pins.  He then checks that the regulator can traverse the terminal curve without disturbing the hairspring. A correction is needed, which he performs.  He then reinstalls the balance and re-centres the hairspring between the regulator pins, and verifies that the regulator traverses the terminal curve without disturbing the hairspring.  Finally, he demonstrates how to close the gap between pins.  He then recaps the whole process, fleshing out more detail. If you follow this process, you have correctly set up the regulator pins, and are ready to set the rate of the watch.  If you are interested in learning more about the effects of the regulator pin spacing on positional rates etc, you can read any literature regarding regulator pins. The etachron system makes adjusting beat, centering the hairspring between the regulator pins and adjusting the gap between the pins very convenient, but the same rules that apply to old style regulator pins apply to the etachron system.  This video explains the basics :    I hope that helps, Mark
    • Some photos of the angles you are talking about, and the changes you are seeing to coil spacing etc. would be really useful. Part of your problem could be that you are closing the pins too far and pinching the hairspring. Adjusting the pin separation should not affect amplitude. Nor should it change the coil separation.
    • Did you try it on a Rolex ref. 16600 specifically? Congrats on the nice condition of the movement in your watch. Even so, remember to check the rotor play or those marks around the main plate may start to build up.
    • Here is a method described in the watch repair book of Mark W. Wiles. Don‘t hammer, just tap very gently!
    • Alex mentions the coils below the stud should remain the same as you move the regulator block along the terminal curve.  Mine do that. What he doesn’t discuss and is used in the other video is how the regulator block is used to adjust rate and positional error.  He also doesn’t mention how opening and closing the pins could and in my case does, alter amplitude  In Alex’s video once he sets the stud he never adjusts the regulator pins yet every new movement I get have the pins signing closed.
