Hello all, I recently acquired a "vintage" Omega  from ebay, and I am looking for advice as to the best way to repair it.
This watch is an Omega Geneve Automatic from probably 67-70 (based on the serial and case Ref#). The movement is a 565, and this is where the issue lies. When the watch arrived I discovered that the crown and stem are not secured, but they just slid right out when I went to adjust the date!
The watch was running when I got it, and I can put the crown/stem back in and wind the mechanism, but it doesn't seem to catch to adjust the hands or the date. (I was able to adjust the hands once right when I got it, but when I picked the watch up an hour later the issue presented itself).
My question then is twofold. I would obviously like the watch repaired, but I am interested in learning more about mechanical movements and teaching myself how to do basic to intermediate repair/cleaning.
Based on the issue I have described,
1-is this problem a relatively straightforward watch related repair? and
2-does anyone think that I would be able to fix this issue myself (after careful study)?
I am a biologist so I am used to working with my hands and am very familiar with learning new techniques etc.
I haven't been able to find any good guides for this specific issue online, and this forum seemed like it had a wealth of knowledgeable people who may be able to point me in the correct direction.
Thank you for your time, I have attached pictures that I believe illustrate the issue.
post-1846-0-29630000-1456159115_thumb.jp
post-1846-0-46500600-1456159118_thumb.jp
post-1846-0-55122500-1456159119_thumb.jp
Here is what you have under the movement. It sounds as if the notch on the bolt has broken and will need replacing. I have know in the past sometimes very hard dirt can get under the bolt and it fails to seat properly to the movement which can also cause the stem to come out. Looking at your stem it looks ok.
post-1154-0-90113500-1456161448_thumb.jp
This is a fairly common problem for omega as the clutch wheel has slipping due to the set lever screw, or in this case, set lever pin being pushed too hard.
For me this is an easy fix, as long as the setting lever hasn't been broken.
All you need to do is take the dial off, remove setting lever, reset the clutch wheel so it's between the setting lever's lever and put it all back together again.
...also, it looks as though the hour hand has been rubbing on the dial. If it's still doing that, stop winding it before it does more damage which will be much harder to rectify than the stem coming loose.
S
    • HWGIKE#57 Valex FEF 190 15 jewels Swiss lever full service and repair This one was waiting for a balance staff replacement in my cabinet parts and case cleaned up with a new balance staff and a 4th wheel as the original 4th wheel had a broken pivot for the off center second hand. I never attempted a balance staff replacement before however I received a Bergeon Molfres (i was hunting it for about 2 years) and with the help of it I managed to remove the old staff and riveted the new one in. It also received a new MS, crystal and the hole for the MS arbor was also tightened. With the new MS now it has an acceptable performance meaning that the amplitude goes up to 280 fully wound, has an acceptable beat error and I have the two nice lines but only dial up, dial down is not as nice and I could not figure out as why. I have the two lines but the amplitude is dropping to around 230 and the lines are a bit hairy. Both dial up and dial down the lines just go up and down without seemingly any pattern. I cleaned the movement two times, and then a 3rd time pegged out the main plate and train bridge holes but made no change. Both the HS collet and the roller table was too lose on the new staff... I did not count how many times I took the balance cock off to sort out the HS collet, the roller table and the beat error, somebody before me also shortened the HS by pushing it out a bit and it seems every time somebody is messing with the end of the HS the protruding bit is most of the time twisted bent etc. This one was probably one of the most challenging repair and service. I might take the new MS out and clean it lubricate it as I just pushed the new one in to the barrel from the retaining ring. Plus started to re-read the theory of the escapement and how to analyse the graph on the timing machine: Greiner Chronografic Record manual. I am also thinking to put the watch on a 24 hour long run with the eTimer SW it once helped me to figure out what was wrong with a watch. There is an interesting part of the Greiner record manual talking about the pallets and the end shake of the balance and pallet staff. Maybe this is my issue? Who could that possibly identify? After a few years now I am still without a clue how could watchmakers make parts I can only see with my microscope or how could/can they carry out complicated services impossible to do.. real magic..... .... ..... before I sent this post while the pics were uploading I had an idea, i was browsing the possible outcomes on the timing machine I had one for magnetism..... so I demagnetized the movement and it is not hairy now.... two really nice lines 0.2 ms beat error still a bit wavy, but a lot lot better..... argh....
