Remove Extra Links From Tag Heuer Link Band
Yeah there are some numbers punched into some of the parts. Namely the base of the tail stock: the mounting block between bed and cross slide: the head stock: and some components of the cross slide assembly:
By SwissSeiko · Posted
As I recall, you have a sherline lathe, so that should be a pretty easy thing for you to make! -
By RichardHarris123 · Posted
I don't know but I think you're correct, slim chance. The bezel looks like a plain ring so maybe one could be made.
